Re: [motm] Re: canare cable... (stripper)
2002-10-25 by elhardt@att.net
Larry Hendry writes: >>And that tool was purchased where? Details please.<< Simply purchased at RadioShack. Assuming the number on the side is its part number, it is 278-248. It's grey in color and is one of those types that has a round finger hole that you stick your finger in and rotate around the cable a few times until it cuts through to the depths set for each blade. The blade depths are adjusted with hex nuts. I practiced on some scrap cable until I got them set just right. -Elhardt
