MOTM 650
MOTM 650
2002-10-15 by ringmod45
Here are a few suggestions.
1) Some sort of buss system, behind the panel, to gang a couple of
motm 650's together for more polyphony.
2) another buss system to allow a companion module, with 16 output
jacks with 4 Continuous Controllers per voice.
RM
MOTM 650
2007-12-28 by ithaib
Hi all,
I don't have one... but just wondering if the 650 does Hz/V & S-Trigger? Any MS-20 users
out there using the 650 as their controller? Or any other Hz/V synths?
Thanks in advance,
Ithai
Re: MOTM 650
2007-12-29 by ithaib
OP! forgot to look in the archives. I found my answer...
--- In motm@yahoogroups.com, "ithaib" <ithaib@...> wrote:
> Hi all,
> Thanks in advance,
> Ithai
MOTM 650
2010-02-16 by James Elliott
Jeffrey, are there any plans on releasing an update for the MOTM650? There are several bugs that should really be addressed. It kinda sucks that I paid $500 for a product that doesn't work as advertised. It was mentioned last fall that some of the bugs were already taken care of and that the new OS was in some kind of beta stage. What's the hold up? If it's a matter of time, there are a number of developers on this board who I'm sure would be willing to take over the responsibility of getting this crap fixed.
-Jim
To: MOTM List <motm@yahoogroups.com>; jdm@...
Sent: Tue, January 26, 2010 1:23:49 AM
Subject: Re: [motm] MOTM-650 bug reporting time
Jeffrey, anything we can do to get this thing fixed? Can we buy the code from you for a couple cases of beer or something?
-Jim
Sent: Mon, January 25, 2010 10:15:49 PM
Paul, any news on the 650 bug fixes? If I'm not mistaken you mentioned that some of the fixes were already implemented back in August....
-Jim
To: MOTM List <motm@yahoogroups. com>
Sent: Sat, September 19, 2009 2:31:31 PM
Need anymore beta testers?
Sent: Thursday, August 20, 2009 6:04:03 PM
Damn it! I would volunteer to be a beta tester for this as I've been bitching about these bugs either privately to Paul or openly to this list over the last two years, however I'll be traveling over the next month so I won't be able to provide any input :(
Anyway, it looks like the two issues I've run into are being addressed:
1) Assert errors when sending CC's to the Aux outputs
2) Hosed error when receiving on the external clock input
I'm really looking forward to this release, Paul & Jeffrey. Other than the frustrations associated with the various bug's I've reported, I really do like the 650. The only reason why I haven't returned it was because I had faith that you two would try to get these issues ironed out :)
Also, I understand that this is bug fixing time, however I had a thought (a 'feature' wet dream) and wanted to throw this out there....
Would it be possible for the 650 to be able to transmit a clock pulse from the "ext clock" jack and have the pulses controlled by midi start/stop messages? I'm imaging a configuration where that jack could be configured to send or receive clock via a menu option. This would allow the 650 to gate a sequencer without sacrificing any of the other outputs (as well as syncing LFO's). That would be super duper handy; and not only that but also a gold medal to those who have remained faithful to the cause......
-Jim
Sent: Wednesday, August 19, 2009 9:27:17 PM
Subject: [motm] MOTM-650 bug reporting time
I have collected MOTM-650 bug reports over the years and sent them in as a
whole to Jeffrey so he can address them. In many cases, he is unable to
reproduce the error. The exception is CC message assignments to the AUX
outputs, that is currently fixed and he is testing that code right now.
Things that people have reported in the past include:
a) running a high rate clock into EXT CLK for the arpeggiators (like into
the audio range) will cause a lock-up
b) scrolling the menus while receiving MIDI data will lock up
c) external MIDI clock seems to run the arpeggiators at 1/2 speed
The current firmware release is V1.3 that shows up when you power up the
device. If you re NOT on V1.3 (there should be nothing else, like RC1 or
V127) email me. There will be a new beta firmware version available in ~ 2
weeks. If you want to be a beta tester email me. Right now, the firmware
updater is XP only, Jeffrey thinks he has a Mac solution that will be ready
in time.
So, I'm asking people with '650s to really pound on them this weekend/next
week, watch for any strange lockups and *write down* what happened and then
repeat it several times so he can also see it.
Fixing the CC messages is a big plus, but I want to get everything quashed
in this release.
Re: [motm] MOTM 650
2010-02-16 by John Audette
I'm new to the 650 and haven't noticed anything other than a couple lock ups. What are the current bugs? I heard CC assignment doesn't work but I haven't tried anyway. I've only had it for a few weeks.
-=john
-Jim
-Jim
-Jim
-Jim
in time.
in this release.
-=john
Re: [motm] MOTM 650
2010-02-16 by Ti_
So...I've mentioned my plight a few times and never heard anyone else with the same problem so one last time...
Does anyone else have problems using their 650 for 4 separate voices on 4 different MIDI channels? i.e. 1 voice controlled by MIDI channel 1, voice 2 on MIDI channel 2, etc.?
On mine voice 1 and 2 work fine, but 3 and 4 are all sorts of screwed up with weird interactions between them and only about 1 octave of usable scale before they start going bizarrely microtonal.
I've got a more thorough discription of my woes if necessary, but i've yet to hear anyone complain of anything remotely like my issues.
~Tim
To: jdm@...; motm@yahoogroups.com
Sent: Tue, February 16, 2010 10:55:31 AM
Subject: [motm] MOTM 650
-Jim
To: MOTM List <motm@yahoogroups. com>; jdm@synthcom. com
-Jim
-Jim
-Jim
in time.
in this release.
Re: [motm] MOTM 650
There is a list in Paul's email below.
In brief, the two that I experience are:
1) Sending cc's to one of the aux outputs (aux 1, me thinks) causes the 650 to crash
2) Sending the external clock input a signal causes it to crash
When I say crash, I mean the 650 has to be rebooted to restore functionality.
-Jim
To: James Elliott <johans121@...>
Cc: jdm@...; motm@yahoogroups.com
Sent: Tue, February 16, 2010 11:00:14 AM
Subject: Re: [motm] MOTM 650
-=john
-Jim
-Jim
-Jim
-Jim
in time.
in this release.
-=john
Re: [motm] MOTM 650
2010-02-16 by Paul Schreiber
Do you have V1.3 (boots up in the LCD)?
This sounds like a V1.2 bug fixed in V1.3
If you have a PC, you can flash the V1.3 code over MIDI. If not, I will do it free, just for postage.
Sent: Tuesday, February 16, 2010 11:06 AM
~Tim
-Jim
-Jim
-Jim
-Jim
in time.
in this release.
Re: [motm] MOTM 650
a) CC messages are in the menu tree, but *not* implemented in the code. It's not a "bug", it's a feature that is/was not implemented.
b) external 'analog clock' (not MIDI clock) to synch the arpeggiators is flakey. It seems to work OK at lower speeds, say < 4Hz. MIDI clock is fine.
If anyone wishes a refund, just return the unit and I'll write a check. My expectations for Jeffrey fixing this is low.
Re: [motm] MOTM 650
2010-02-17 by Jeff Laity
I send CC1 to Aux 1 all the time, that's all I use it for. I'm using it in monophonic mode, perhaps the problem happens when using the 650 as a multi-channel converter.
I thought that someone was re-writing the code for the 650?
NOTICE: This electronic mail message and its contents, including any attachments hereto (collectively, "this e-mail"), is hereby designated as "confidential and proprietary." This e-mail may be viewed and used only by the person to whom it has been sent and his/her employer solely for the express purpose for which it has been disclosed and only in accordance with any confidentiality or non-disclosure (or similar) agreement between TEAC Corporation or its affiliates and said employer, and may not be disclosed to any other person or entity.
Re: [motm] MOTM 650
2010-02-18 by James Elliott
I've posted a detailed scenario in the past, I will do so again to ensure that this issue isn't down played. Personally, I think it is serious. If it is a problem with my specific 650, WONDERFUL, I'll just send it back to Paul to get it fixed/replaced. Else, it is a BUG that probably won't be fixed and not an unimplemented feature ('cause the other aux outputs work just fine). I'm leaning towards bug because Paul never said, "you know what, I can't replicate that on mine, maybe you should send yours in for replacement", especially because I've brought this up many times (since 2007).
-Jim
> General Problem: My 650 quits responding to midi when I send midi
cc's to control aux1. When I say quit responding I mean that the output jacks do not transmit a signal - the midi LED still responds to midi. One of two things happens once the 650 is in this state.
1) If I perform the following actions, then the 650 begins to respond to midi again (however it will lock up again if I send midi cc's to aux1)
> -Press "ESC"
> -Scroll to, and then select, "Module Actions"
> -Scroll to, and then select, "Load Patch"
> -and finally, load a patch
> 2) If I don't follow the steps above, I get various assert errors depending on different buttons that I press
> -L612: I get this error when I press "Enter" after a lockup
> -L2039: When I press "Inc" after a lockup
> -L2167: When I press "dec" after a lockup
-L548: First I press "ESC", which allows me to scroll through the top level menu, then press "Enter" on any of the second level menu items
> My 650 is setup as follows:
> -Global options:
> 1) Voice Type - 1/1/1/1
> 2) CtrlMidi Chan - 1
> 3) Trig PWM - 10ms
> 4) VelScale - 8 Volts
> 5) Backlight - Auto
> 6) TunTable - 12 Tone
> 7) Note Inv - Off
> 8) Priority - LastNote
> 9) Clock - Internal
> 10) IClk BPM - 120.0
> 11) Midi Clk - Transmit
> 12) Patch Rx - Disabled (I also tried enabled, whatever that does?)
> 13) SysexSys ID=Global
> -VoiceGroup 1 Settings:
> 1) VG1 Midi Chan - 1
> 2) VG1 Allc - Solo
> 3) VG1Glide - Off
> 4) VG1PBend - 24
> 5) VG1GType - Normal
> 6) VG1 V/T - Velocity
> 7) VG1 Aux - CC12 (Tried others as well with the same issue resulting)
> 8) VG1AuxSc - 8 Volts
-VoiceGroups 2 - 4 are set up exactly like group 1 except that the PBends are set to 0, and the Aux Midi CC's are set to different values (13, 14, 15).
> -Both Arps are turned off.
> **This also happens in other other voice modes as well 4/poly1, 4/poly2, 2/2/poly1, etc.......
Sent: Wed, February 17, 2010 1:07:35 PM
NOTICE: This electronic mail message and its contents, including any attachments hereto (collectively, "this e-mail"), is hereby designated as "confidential and proprietary. " This e-mail may be viewed and used only by the person to whom it has been sent and his/her employer solely for the express purpose for which it has been disclosed and only in accordance with any confidentiality or non-disclosure (or similar) agreement between TEAC Corporation or its affiliates and said employer, and may not be disclosed to any other person or entity.
