Surface Mount Devices/Update
2002-10-02 by Paul Schreiber
Sounds like a way to short pins to each other, as well as nearby vias. BTW: Many of the 500/600 Series (but NOT all) modules will have SMT, and therefore are 'semi-kits' like the MOTM-900 power supply is. The main pcb is pre-soldered, but you still attach wire/pots/jacks, etc. I will include self-test code when possible. The SMT lead spacing is in most cases not "horrible" but maily the problem is kitting (want a teaspoon of caps the size of a speck of pepper?). There are ~400 modules on backlog (including the '480) with about 115 being assembled. At least I won't be bored :) All pumped up, as the first of a long line (hopefully) of super whiz-bang 'hybrid' modules (digital control of analog functions) I start designing tomorrow (well, actually the SW breadboard). In many cases, the SW is the pacing item, and as Tonk K. will testify, can extend towards infinity, time-wise. I also hope to get the production sample of the WaveWarper finished by the end on this month. The pacing item is the UK-made rotary switches, still 10 weeks away from arriving. Gack......but I have 3 leftover :) Paul S.
