MOTM 940/Moog 904A comparison
2002-08-22 by alt-mode
Folks, I *finally* finished my 940/904A comparison. I won't give you any excuses for the time it took. The material isn't very exciting, in fact it is down right clinical. Please go to: http://www.alt-mode.com/~motm There are 4 files, 2 are .wav, and 2 are .mp3 (128K encoded). One test has the 940 on the left and the 904A Right (if you don't have your left and right straight, it will be hard to tell which filter is which). The second test is the same sequence but in mono alternating between the 940 and the 904A (940 first). The sequence is repeated with a low resonance, medium resonance, and high (but not oscillating) resonance. I tried to tune the filters to each other as closely as possible by getting the filters to oscillate and using a tuner to match them. The test setup was a single MOTM-300 SAW out into an MOTM-830 to attenuate the signal. The 830 was feed into both filters and then into two Moog VCAs driven by Moog EGs. The 904A was run in the middle response mode (2). An Encore Expressionist provided MIDI->CV conversion and CC#7 was used to sweep the filters after going through a MOTM 820 to smooth out the steps. The output of the VCAs went into an Avalon AD2022 preamp, mostly to even out the levels, and then into an Apogee Rosetta converter into a MOTU 2408 into Logic Audio. Interesting observations: - The filters sound pretty close to each other in this test - I didn't quite get the resonance even between the two filters on the medium resonance test - The resonance on the 940 is very touchy, going into full oscillation by about the 12 o'clock position - The phase from the two filters is reversed - causing some phasing in the stereo test - The output of the Moog filter was actually louder than the 940! - The DC offsets are interesting between the different filters and tests... In this test, the filters sound *very* similar. In playing with the 940, I found it had a neat character but didn't quite feel the same as the 904A. It wasn't bad, just different. I think a lot has to do with the range of the knobs. There is a lot of range in a short span on the 940, particularly in the resonance! Fire any questions you may have. I thought about expanding this test to other filters but decided I didn't want to spend the time. I could be persuaded if folks think there is a benefit. I'm not sure if this simple sweep test really gets much of the character of a filter. Lots of character comes from how it reacts to an EG or fast changing CV. If someone has an idea for a good filter test, I might be interested in giving it a go. Eric
