Hello and my comments on the user interface discussion
2002-08-13 by pugix
Hello everyone, This is my first post since lurking for about a week. I am awaiting my first MOTM order. But I'm not a newbie. I was building custom modular synthesizers over 20 years ago. From scratch. Mostly Electronotes based, but with some reverse-engineered Serge influence. I faced the panel design issue, too, but I had the luxury of having my own requirments and not those of a general customer base. I won't go into detail on my panel designs. However, I would like to say that the MOTM panel design constraints (grid format, patch bay below knobs, uniform knob size, etc.) result in a uniformity that I find aesthetically quite pleasing. I experience the modular synthesizer as a field of possibility, open to realization in often unexpected ways. I like the indeterminate starting point, before any patch cords are plugged. (Have you noticed that most photos of synthesizers are sans patch cords, which make it look cluttered and chaotic?) It must have been this predilection of mine that led me to make my own modules quite minimal. For example my noise generator had three output jacks (white, pink, random). Then I would use separate S&H modules and patch the noise inputs there if desired. This results in great flexibility, but also requires more patch cords. I came to appreciate the combination of frequently used functionality, such as patching the noise by default as input to a S&H. (The 101 module is a great example of this design principle, by the way. Can't wait to get my hands on it.) Also, the 410 Triple Resonant Filter contains two embedded LFOs. I think the MOTM designers have done an excellent job of packing functionality into these modules, while not sacrificing flexibility. Some may disagree. I was wondering what you all might have to say regarding this aspect of module design, which is certainly as important -- if not more so -- than the issue of knob sizes and panel placement. Panel real estate has always seemed precious to me. I want to pack as much function to the square inch as I can. I think MOTM is quite good in this respect. But the 802 Lag Processor, (and the 320 LFO is similar in this regard) seems to use a lot of panel space (2U) for the function. I do understand that this has to do with the circuitry, and with wanting all those IO jacks. But, as the 390 micro-LFO offers compromised features to gain more functional density, might we not want a similar micro-Lag Processor that is 1U in width? You catch my drift. I look forward to your comments. Richard Brewster
