How Low Can You Go?
How Low Can You Go?
2002-08-12 by Craig Critchley
What's the low-frequency limit for the '420 and '440 filters?  I see the
inputs are AC coupled, and I'm wondering if the bipolar buffers limit the
low-frequency response as well.
I'm interested in filtering control voltages, inspired partly by the '101
vibrato circuit and partly by trying to make a PLL with two '300's and the
ring modulator from the '110.  I used the '820 lag as a cv filter for the
PLL with interesting results; depending on how you adjust the frequency and
tracking on the oscillator in the loop along with the lag time you get some
interesting 'wobble' early in the note, and it changes the timbre of the
note overall (like FM, I'd guess).  But as I understand it, the '820 would
have a -6dB/oct response unlike the other filters.
Are there any filters in the works that will go down to DC or are they all
strictly audio filters?
                    ...Craig
Re: [motm] How Low Can You Go?
2002-08-12 by media.nai@rcn.com
Afaik, only the 830, 820, 700, and half of the 110 can process DC.  I don't
know about the 130 or 190, even though I've asked a few times.  I guess a
320 can be considered a DC processor of some sort -- it has DC inputs and
can produce a DC output for considerable length of time.
My, that sounds ambitious :)  Let me see if I understand what you mean. You
are trying to have one 300 track another 300, taking the square outputs of
both 300's, using a 110 ring mod as a "phase comparator", smooth the output
with an 820, then send the output to the second 300 using the FM input??
Or am I completely lost here??  I think I understand how a "four quadrant
multiplier" would give the sum and difference frequencies using sines, but
I don't see how it would give you just the difference like an XOR using two
squares.  Wouldn't it give you something much more complex??
Does it eventually lock??  Are the resulting outputs of the two 300's 90
degrees out of phase??
I think you would get FM if the 820 was set too fast, and afaik, some
ripple is typical for a "type I phase detector".
Regardless whether it works as a PLL or not, that sounds like quite an
interesting patch!!
Yes, the other MOTM filters are steeper, but they won't pass DC.  The PLL
circuits I've seen only use one cap to smooth the VCO control voltage, so
afaik, that would make them 6dB/oct filters as well.
2002-08-12 by groovyshaman@snet.net
> <media.nai@...> responded:
don't
I think only the 820 would be usable for LP filtering control voltages (slow
waveforms).  Of course, LP filtering a flat DC signal would not produce
much. :)
Ok, correct me if I'm wrong, but isn't soft sync basically a form of PLL?
You
output
two
Hmmm... The 110 produces both sum and diference sidebands, so when one tunes
both 300s perfectly at 1000Hz, there will be a resultant 2000Hz upper
sideband signal and a DC output corresponding to the difference in the phase
of the two input waveforms.  Now if they're slightly detuned, say by 1Hz,
then the 1Hz low band signal could be retrieved from the output by LP
filtering with the 820.  In any case, I would think the PWM settings of the
two 300s would be critical in this application.  If set to anything other
than precisely 50%, it would add either positive or negative offset to the
LP filtered control voltage.  It could be interesting to try using the PWM
input to control the offset.
Another issue, when using square waves through a ring mod, there are *tons*
of side bands due to all of the odd harmonics present.  Why not use sine
waves?
<snip>
> interesting patch!!
Agreed!  I'm curious Craig, what led you to this experiment?
George
> don't
a
and
(slow
> much. :)
Well, that's true.  :-)  The 101 vibrato has a low frequency bandpass and
putting two together I got curious about low frequency filters in general.
> the
It certainly produces a different sound; you don't get the overtones from
the reset, but you do get some FM-like effects, particularly around the
attack while the loop vco is still hunting for the right frequency, if you
set the filter time long enough.
> You
of
> output
quadrant
but
> two
tunes
phase
*tons*
> waves?
Actually, I am using sine waves from the '300 as the inputs to the ring
modulator, patching other outputs through a filter for the audio output.
I'm not using the PWM inputs, I'm using FM.  I had the note voltage patched
to both 1v/oct inputs, with the loop vco detuned so it would have some work
to do, then I switched the loop vco to another fm input so I could change
how well it tracks the 1v/oct note.  Different amounts of initial detuning
produce different timbres as well, I suppose because of phase and some
leftover FM, but the VCO's can't start too far apart or the loop won't find
the frequency.
I would imagine that a ring modulator and an XOR would produce similar
results for square waves, since an XOR is multiplying if you call the states
+1 and -1.  Since the next module after that is a low-pass filter, the extra
harmonics might not make much difference.
> <snip>
> > interesting patch!!
Mostly curiosity after reading about PLLs.  I'd seen various 4046-type PLLs
in the past but then saw a block diagram for a sine vco with a balanced
modulator and thought "hey, i have all that stuff in my motm..."
> George
                        ...Craig
>>(slow waveforms).  Of course, LP filtering a flat DC signal would not
>>produce much. :)
Right, I was trying to list all the modules that can process DC.
Not afaik.
>>tunes both 300s perfectly at 1000Hz, there will be a resultant 2000Hz
>upper
>>phase of the two input waveforms.
Right, so if you filter the AC component from a phase comparator using a
four-quadrant multiplier (a linear type I ) the resulting voltage is the
difference in phase.  So the cap is a filter.  In contrast an edge-detector
(type II) phase comparator outputs either positive or negative pulses when
the two signals are out of phase that charge or discharge the cap.  So the
cap holds the VCO control voltage.  I don't think that can be done using
MOTM, or at least not yet :)
Afaik, they would both have to be square.
>waves?
Apparently, Craig got it to work, but I've never seen a type I phase
comparator use sine waves.  Then again, I'm not an EE.  However, I've spent
a bit of monkey time with a 4046 using pulses.
So you are saying that it locks eventually??  Wow!!
>the frequency.
That makes sense, but I'm as bit surprised that it finds it locks at all!!
I would like to hear your theory of how this works.  What is the phase
relationship between the two 300's when locked??  I'm guessing that when
the two VCO's are at the same frequency the ring mod output is double that
frequency (which is filtered out) and a DC offset that approaches zero as
the two signals approach 90 degrees out of phase.
>>states +1 and -1.  Since the next module after that is a low-pass filter,
>>the extra harmonics might not make much difference.
The output of an XOR will be a frequency equal to the difference in
frequency to its inputs.
