1v/oct trimming: how does it work?
2002-08-11 by Jeffrey Pontius
I've assembled several kits where adjusting a trimpot is used to set a
1v/oct 'scale', which I've done by using a keyboard, Korg tuner, and
adjusting the trimpot until (usually, but not always) the octave pitches
on the tuner stabilize (say, at A). I'm sure most of you have done this.
I would appreciate a basic explanation of how adjusting the trimpot and
sending 1 volt jumps (from the keyboard) enables the circuit to
'stablize' at 1v/oct.  To me, a trimpot is a small potentiometer, so I
assume that there is some component in a sub-circuit that is being
'permanently' changed.
Are the tolerances of components used critical to achieving a 'stable'
1v/oct?
Thanks [novice electronics module assembler], Jeff
Re: [motm] 1v/oct trimming: how does it work?
2002-08-11 by John Blacet
"Are the tolerances of components used critical to achieving a 'stable'
1v/oct?"
--Oh to be sure they are! One of analog synth designs biggest
challenges.
Paul has a great circuit analysis in the Ultra VCO manual; check it out.
John Blacet
Blacet Research
http://www.blacet.com
