MOTM-450 is ALIVE!
2002-08-10 by Paul Schreiber
Yea! Here are some AP plots of the MOTM-450 filter section. www.synthtech.com/misc it's a small 12K 2pg PDF file. If you've heard of an 'elliptical response, but never seen on, now is your chance :) It's on the HPF stage. Things to note: I need to verify that on the Moog 907/914, the frequency indication is for the *center frequency* or the -3dB point. Looking at the graphs, it's the -3dB point. I'm not sure that's "accurate" or not. The particular circuit topology used is *very* low noise. Look at the noise floor on the FFT plot! Its down over 130dB (in the nanovolt range). I still have to "gain balance" the filters. Note the LPF is unity gain, the BP is like -15dB down (around a gain of 1/6th), This is just resistor tweaking. Next I'll add the 10 pots (groan) and make more pretty pictures. Yep, it's a Sat. night geekfest (pathetic). Paul S.
