MOTM-450 question
2002-07-31 by Paul Schreiber
I'm frantically working on the MOTM-450 Fixed Filter Bank prototype pcb, as tomorrow is the end of the cheap prototypes at the board shop :( (they are TRIPLING the price!) If the behind panel depth was *increased* 0.75", will this hunt anyone? It may mean it won't go into SKBs. Please reply if it messes you up (I don't want to see 45 "I'm fine" emails). This is not to say how the final partition is done. I may have 2 pcbs with filters on both. The pots used are 10K log, Bourns rt angle pcb mount. So, I have to have at least a small board/connector just to wire up to the pots (no way I'm wiring up to 15 of the 'raw' leads). I can't fit all the "active circuitry" on a standard depth pc board (which is 4.25" deep), so now it's 5.00" deep. If I go to 2 boards with filters on both, they will both be standard depth. I added a wet/dry blend knob. Paul S.
