Starting with one filter, advise please
2002-07-02 by Robert van der Kamp
Hi all,
I asked this already half a year ago, but since Paul has added a
couple of filter modules in the meantime, I thought I ask again.
I'm (finally) buying my very first MOTM modules: the power supply and
one (maybe two) filters for audio treatment of synths and samples.
I'll add some more in the future, of course. ;)
I'll get the kits, but I'm not very experienced with soldering, so the
kits will have to be relatively simple, as a nice first experiment.
Now what filter module(s) should I get? I know this is a kind of
general question, but anyway.
Additionaly, am I right that there's still no MOTM envelope follower
module available? Even in the 500 series? If not, what should I get
to have one? And will it have the same panel? I'd like to drive the
filter's freq and res functions via the envelope follower, allowing
me to liven up VA synth sounds without having to tweak the filter
manually during the song.
Finally, I saw on the order form that there's a non-US version of the
power supply available. Being from Holland, I guess that's the one I
should get?
Robert
Re: [motm] Starting with one filter, advise please
2002-07-02 by groovyshaman@snet.net
Hello Robert,
responses inline...
To: <motm@yahoogroups.com>
Sent: Tuesday, July 02, 2002 3:46 AM
Subject: [motm] Starting with one filter, advise please
> Hi all,
The kits are pretty easy to build, even for a beginner.  The most important
thing is to take your time and follow Paul's excellent instructions
completely, and everything will go well.  It's also very important to have
the right tools.  Paul mentions this on the FAQ page of the Synth Tech
website: http://www.synthtech.com/motmfaq.html
You will also be sent the "MOTM General Assembly Guide" with your first
order, and this gives excellent advice and tips for successful kit building.
The most challanging kit is the 300 VCO, followed by the 440 filter (until
the 480 comes out, yikes!).  The easiest are probably the 380 QLFO, the 850
Pedal and the 800 EG.
If you are only going to get one MOTM filter and will be using it for audio
processing, I would recommend the 410 Tri-Res Filter.  This filter is the
bomb!  It's basically three bandpass filters that sweep somewhat
independently.  It sounds very rich and lush, and can do a wonderful stereo
"wash" (separate outs for each filter).  With the sweep depth set to 0, it
can also be used as a fixed filter bank.  There is tons of voltage control.
And if you want to increase the power of this module later, you can build
Tony Allgood's (Oakley Sound) awesome OMS-410 companion module.  Check it
out here: http://www.oakleysound.com/oms-410.htm
Correct, no envelope follower (yet) and no timetable for one (yet) - bummer,
eh?.  If I were you, I would call Paul and discuss this. <grin>  The 500
series will be much more "strange" than a simple EF (and much more $$$)!
In the meantime, you have a few options.  The simplest/quickest would
probably be to pick up the synthesizers.com EF:
http://www.synthesizers.com/q118.html  It comes pre-assembled and includes a
preamp.  It's electricaly compatible with MOTM, but alas its form factor is
close-but-no-cigar.  You would have to drill different mounting holes, and
then you have to deal with the panel width being different than MOTM.
A more challanging choice (but better fit) would be to pick up Oakley's EFG
kit: http://www.oakleysound.com/follower.htm  You would have to order the
parts yourself and then build it.  (Tony does have excellent instructions
and provides excellent support.)  You could order a "Stooge Services" MOTM
front panel from the quite respectable J. Larry Hendry (if he ever gets off
that Harley) and the fit would then be perfect.  JLH's website:
www.wiseguysynth.com
Another option (I would highly recommend) would be to pick up the 850 Pedal
Interface module.  Yea, it's not an EF, but you can sweep filters with your
feet while your hands play music!  And it's a piece of cake to build.  I
have two == fun!
> should get?
The MOTM FAQ discusses the European version of the 900 (at the bottom of the
page).  You might want to confirm with Paul before ordering.
> Thanks,
> Robert
Have fun,
George
2002-07-02 by Adam Schabtach
I have a -420 and a -440, and I just got the Happy Email from Paul saying
that my -410 kit is on the way. Of the two that I have, the -420 is a little
more flexible because of its three modes (lowpass, highpass, notch), but I
find the sound of the -440 more pleasing.
Neither of the filters I mentioned have voltage-controlled resonance. If you
want to "liven up VA synth sounds" you'd probably prefer the -440 or the new
-490, since they're four-pole lowpass filters similar to those found on many
"classic" analog synths.
I just put up a couple of MP3 files of the -440 in action on my website: go
to http://www.studionebula.com and click the Synth link, then click the 29
June link.
Note, however, that the -440 is definitely not one of the simpler kits. It
has a really dense PC board. According to Paul's difficulty ratings, the
-490 is much simpler, but I haven't built one. Buy a good soldering iron and
get a small tip for it. You might also want to search back through the
archives of this list for discussions about tools and soldering, unless
you've been reading regularly over the past few months. A couple of folks
provided some really helpful advice after I fried the tip of my soldering
iron because I didn't know about keeping it properly tinned.
--Adam
RE: [motm] Starting with one filter, advise please
2002-07-02 by John Loffink
The 440 filter does have VC resonance.
John Loffink
jloffink@...
>; filter's freq and res functions via the envelope follower, allowing
want to ";liven up VA synth sounds" you'd probably prefer the -440 or the new
Wow, right you are. I stand corrected. I plead guilty due to building the
filter while in a haze of codeine cough syrup and antihistamines.
--Adam
(suffering from seasonal allergies exacerbated by forest fire smoke)
