Re: MOTM-800 EG f
2002-06-30 by vulture.squadron@syol.com
> While you are pondering the swap, you can increase C9 to say 6.8ufd or 10ufd to proportionally > increase the overall times of Attack/Decay/Release, but it does effect BOTH min and max times. If > you want slow, evolving pads then you really don't care about 500us Attack times, you would > rather have 20 second Release times. The current 3.3uf cap has about 10 seconds MAX times. I have > had customer with multiple EGs swap out say 2 or 4 caps for 10ufd: create 2 "short" EGS and 2 > "long" EGs. hello all, if there was time in the stooge schedule, i'd certainly consider a 1U sized MOTM800 expander panel - this would have two columns - one for eight or so switches to switch between 'long' & 'short' envelope, the other column would be for the LEDs from (was it?) Dave B's mod it's only really worth doing this in true MOTM colours though - have we missed the boat on this..? anyone else interested..? cheers paul b
