>>>2) JH Scanner Module: The "scanner" described on Juergen Haible's website
>would make a dandy module by itself. There would be four or eight inputs
>that can be "morphed" between, under voltage control.<<
>If you don't mind mixing in modules from other manufacturers, probably the
>only way you'll get that feature is to buy Doepfer's two module set.
