2 Pots & 10 Jacks on 1U
2002-05-16 by coyoteous
How crazy is this?  I made a graphic mock up (standard MOTM
spacing) and it looks okay, but the top jacks are closer to the
bottom pot than the top pot is - too close?
I put the mock up in the files area: 2P10J.jpg
The labels are meaningless, just left over from what I started
with (for the most part).
Barry
RE: 2 Pots & 10 Jacks on 1U
2002-05-16 by mate_stubb
Not crazy at all. Looks like you left the pot and jack spacing
standard, correct?
Don't worry about the top jacks being too close to the pot - every
MOTM module sold has the bottom pot so close to the top jacks that
the bottom numbers have to be left off the pot tic marks. Your
spacing is actually quite a bit more spacious than that.
Be aware that for DIY, you will only have two pots available to mount
a circuit board from if you use Larry's Stooge brackets. If you have
a fairly large pcb to mount, you may have to do something creative.
Moe
