[motm] Annoying MOTM envelope behavior
2002-05-08 by elhardt@aol.com
Ever since I built my MOTM I haven't liked the way the envelopes worked, yet
I've never heard anybody else comment on them.  I'm wondering why not.  Is it
just me that experiences the following problems?
1)  I patch up a sound and hit a key on the keyboard to trigger the sound and
it sounds OK.  Then I start playing and all of a sudden the sound gets
brighter and louder (I have envelopes going to both filter and amp).  This
isn't right.  The envelope should not output higher voltages because I'm
playing faster or more legato, yet it does.  I finally got around to scoping
it and confirmed it.  With the exception of a little initial spike the ADSR
outputs about 4 volts max.  Yet at certain settings if I play a fast trill I
can push it up to about 6 volts.  Set A=0, D=6, S=7, R=4 and go into the a
filter FM input and you'll see what I mean.
2)  If the Sustain level is set way up to about 10, then the Decay acts like
an Attack.  I can set the Attack to 0 and move the Decay around to get
various length attacks.  It seems to control the attack time from the normal
4 volts up to a higher voltage which is set by the sustain level.  Strange.
3)  I can set Attack to 0, Decay to 0, and Sustain to 10 to get plain organ
type envelope, yet the attack portion is too soft.  It's impossible to get a
hard solid sound at this setting.
And I haven't even gotten into the somewhat artificial sound of the envelopes
either because I need to compare side by side with another synth.  But they
almost sound linear instead of exponential (even though I'm sure they're not)
and don't seem to have a really good bouncy and punchy quality I like.  But I
need to compare to others before I can say for sure what's going on here.
I've never experienced these things with any of my other synths.  Am I the
only one dealing with these issues?
-Elhardt
Re: [motm] Annoying MOTM envelope behavior
2002-05-08 by Paul Schreiber
Hmmm...
Just a few initial questions:
a) Are you *sure* these are the "Rev B" EGs (with the TRIG wire mod)?
b) What is the GATE source?
c) Are you using the TRIG input as well?
> -Elhardt
2002-05-09 by elhardt@aol.com
Tony Karavidas writes:
>>I see all the same behavior (just popped it on my scope) except for #3. If
the attack = 0, I get a 315uS rise time regardless of the other three pots
(unless of course the release falls into the next attack phase.  I do see the
sustain portion climb to 6.8 V under certain pot settings. Hmmm.<<
It's all very strange.  I was going by my ear on #3.  I just don't seem to
get a hard attack but I haven't digitized it to see just how fast it is.  I
did however try your UEG for comparision even though it's not a typical ADSR
and I didn't experience any of these problems.
synth1@... writes:
a) I bought all my 800's after the trig mod, so yes, they are all Rev B.  I
have a total of 6 of them.  Just to be sure I didn't make a global mistake
when I built my first batch, I just connected one from my second batch and it
behaves the same.  Since Tony or Encore also sees these things, I have to
rule out a mistake on my end.  That's the confirmation I wanted.  I surprised
the rest of the list is silent.
b) My gate source is the Kenton Pro-2000.  It's set to a 5v gate, but behaves
the same when set to 15v.
c) I'm not using the trigger input.
It's almost as if I'm playing on a touch sensitive keyboard when using my
MOTM.  How I play affects the ADSRs and thus the brightness and loudness of
the synth.  That of course shouldn't be the case.
-Elhardt
2002-05-09 by Scott Juskiw
I have four 800s and I tried to replicate the problems you are
seeing. I patched the envelope into the FM input of a 300 so it was
easier to hear the envelope. I tested using the Gate out from a
Pro-One into the GATE input of the 800s. I didn't put anything into
the TRIG input.
I used A=0, D=6, S=7, R=4 as you suggested but couldn't find anything
bizarre; the envelopes behaved as I expected them to. However if I
use A=0, D=10, S=10, R=10 and trill rapidly then I can get a
sustained 6.4 volts out. I wasn't expecting that.
I get this one too. If I set A=0, D=10, S=10, R=0 then the envelope
hits 4 volts almost instantly and then exponentially decays UP to 5
volts over a period of around 15 seconds. If D=0 then the decay UP to
5 volts is almost instantaneous.
Hmmm, mine sound snappy enough to me. I usually don't even use A=0
because I find  it too snappy at that setting. Maybe there's some
extra resistance in your Attack pot (it's not 0 ohms when fully CCW).
If I set my Attacks to greater than 0 then my results are much closer
to yours.
They sound exponential to me. The only thing I miss is a really long
attack time, 20 seconds would be nice. If I ever find some good 5 Meg
log pots I might try replacing my Attack pots.
I never noticed these 800 oddities until you mentioned it. I'm glad
you brought it up, you're certainly not alone.
2002-05-09 by Craig Critchley
I'm definitely seeing the same behaviour Scott describes.  I can't decide if
I see Elhardt's first problem or not.  It seems like the voltage output is
"lifted" partially if there's insufficient release time.
This seems to be a problem only for short attacks, below about 2 or so
(25ms).  The effects are less pronounced for non-zero attack and tend to go
away after about 2.
As for the second problem, it seems that there's the initial attack to
almost 5 volts, a short decay down to 4 volts, and then the actual decay to
whatever sustain level, whether its above or below the initial 4 volts, when
you have A=0.  Again, this is only a problem for short attacks; the longer
the attack the less pronouced this initial droop is.  With low sustains,
this "droop" also contributes to decay time, so if you set sustain=4 or 5
the minimum decay is about 25ms at A=0.
Elhardt, I suspect the "lack of attack" you hear is due to the second
problem.  The envelope is "decaying up" briefly, even when you have D=0.
I tried both keyboard gates and the pulse output from a '320.
                        ...Craig
To: <motm@yahoogroups.com>
Sent: Wednesday, May 08, 2002 10:08 PM
Subject: Re: [motm] Annoying MOTM envelope behavior
yet
Is it
> the TRIG input.
and
This
scoping
ADSR
trill I
a
like
normal
Strange.
organ
get a
> to yours.
envelopes
they
not)
But I
2002-05-09 by Paul Schreiber
I suspect that this oddness is when the '800 is used with GATE only.
It probably has to do with the attack times less than the internal trigger pulse time. I would be
curios what occurs when a Pro-2000 is used with BOTH gate and trigger (you assign an AUX out to
VTRIG).
Also, I can see that if attack is very short (say 0) and decay is long (say 4 or more) when
sustain is at 10 it acts strangely. Think about it: what does this setting mean? How can you
"decay" when the sustain is at max? Where do you "decay" to? I suppose it should just sit at the
sustain setting (~+5V) and wait for GATE to drop, going into the release phase. But it may not.
However, I don't forsee a reason to redesign. It *is* a cheap, simple circuit.
Lastly, it you want just "organ" envelopes, use the MOTM-820 with GATE as you input.
2002-05-10 by Scott Juskiw
>trigger pulse time.
That seems to be the ticket. Once I increase A from 0.0 to 2.0 then
the problem goes away (i.e. the envelope instantly reaches 5 volts
and stays there, it no longer decays slowly up to 5 volts).
>release phase.
That's exactly what I would expect it to do: decay from the attack
peak of 5 volts down to the sustain level of 5 volts, a simple organ
type of envelope. I wouldn't expect the envelope to slowly rise from
4 volts to 5 volts while sustaining.
>But it may not.
Consider it a unique envelope contour specific to the MOTM line.
2002-05-10 by elhardt@aol.com
As far as #2 and #3 problems, they are not of such a big concern to me.  For
instance on #2, I can set the sustain level lower and be sure that decay is
set to 0.  I noticed the problem probably by changing from one type of
envelope to another and thought it strange that decay acted like attack.
Somebody else seems to have noticed what I did (when sustain set to 10), the
attack brings the envelope up to about 4 volts, then the decay basically
decays in an upward direction (acting like attack) to the sustain level.
But my main problem is #1.  I will try to also use a vtrig from the Pro-2000
to see if I can solve the problem that way.  If so then no need to worry
about it further.  But if that doesn't work I don't know what to do other
than drag my Doepfer upstairs and use its envelopes.  For those people who
say they couldn't reproduce #1, I'm wondering whether your 800s are Rev A or
Rev B.  You should really see the problem when playing relatively fast and/or
legato.  It think the longer the release time the more obvious.  Playing like
this pushes the output of the envelope higher and changes your sound
according to where you've patched the envelopes to.  I almost get the
impression that the release portion doesn't have time to drain the envelope
back to 0v as it were, and the new note just builds ontop of the old one
increasing the voltage.
I'll let you know whether a gate + vtrig solves the problem.
-Elhardt
scott@... writes:
 sustained 6.4 volts out. I wasn't expecting that.<<
That's basically problem #1 I described.  If you trill fast or play fast at
the first setting you should also see it rise up close to or beyond 6 volts.
I guess with the extreme settings of 10 it's only going to become even more
obvious.  I just wanted to keep the sustain away from 10 so I wasn't
overlapping into problem #2.  I just wanted to be sure others experienced it
so I know it's not just me.
-Elhardt
