Future idea for MOTM Ring Mod
2002-04-30 by Scott Evans, Gen Mgr
One cool thing I had noticed on the Serge Ring Mod has a control voltage
input over the Mode of operation, from VCA to AM to RM. Perhaps an idea
of this sort could be considered for the next MOTM Ring Mod.
Scott
Re: [motm] Future idea for MOTM Ring Mod
2002-04-30 by jhaible
Let's see: the Pan/Fade stuff will come with the 130.
I think along these lines at the moment:
Dual VCA, with one of them switchabe lin/expo,
and the other one switchable lin/RM, where RM means
continuously variable from direct signal over AM to RM
(like that Korg PS-3100 modulator, or the CS-80 Ringmod).
Just an idea - nothing promised yet. But I'll come up with something
you will love, and which will not make the 130 redundant.
JH.
-----Urspr\ufffdngliche Nachricht-----
Von: Scott Evans, Gen Mgr <esresource@...>
An: MOTM <motm@yahoogroups.com>
Gesendet: Dienstag, 30. April 2002 02:00
Betreff: [motm] Future idea for MOTM Ring Mod
> Scott
2002-04-30 by Adam Schabtach
What\u2019s the difference between AM and RM? I mean, isn\u2019t a ring modulator essentially a multiplier of two signals, which means that the instantaneous output is the product of the instantaneous amplitudes of the input, which means amplitude modulation?
--Adam
2002-04-30 by Scott Juskiw
At 8:02 PM -0600 2002/04/29, Adam Schabtach wrote:
>What's the difference between AM and RM? I mean, isn't a ring
RM is a four quadrant multiplier, whereas AM is only two quadrant. If
the control voltage in an AM goes negative, the output signal is
clamped at zero. If the control voltage in RM goes negative, the
output signal is the inverse of the input signal (180 degrees out of
phase).
You can see (hear?) this in operation with the 110. Put a 320 square
wave into the CV input of the VCA (i.e. the AM half) and your
favourite 300 waveform into the IN. The output goes on/off/on/off.
Now try it with the RM half. The output is on/on/on/on with a bit of
a click as the output waveform is switched between normal and
inverted.
Right you are. Thanks. George Kisslak wrote to me privately and suggested
that this might be the difference, which forced me to pull three different
books off my shelf in order settle the matter in my own mind. You're both
right. To quote one of my old college textbooks, "amplitude modulation
consists of causing the carrier amplitude to vary in correspondence with the
instantaneous magnitude of the audio frequency signal (called the modulating
signal)."
I'd love to, but I haven't received my 110s or 320s yet, and I haven't built
either of my 300s yet.  :-)
--Adam
2002-04-30 by Paul Schreiber
Well at least I'm only 1/2 to blame :)
After sending that quip I realized that I could do Scott's demonstration by
using my 420, self-oscillating, in place of the 300.  :-)
--Adam
