Re: making MTA cables
2002-04-22 by mate_stubb
>>>> You don't need a special tool, just a very narrow screwdriver. I do this all the time by just placing the wire across the connector and then pushing down on one side and then the other with a flat edge screwdriver that's narrow enough to fit in the hole. Or, if you have two narrow screwdrivers, you can try doing both sides at once. <<<< I use a fairly large pair of needlenose pliers with blunt ends. Open it slightly so that the points are on either side of the blade, and push. Moe
