Re: [motm] JOYSTICK DIY Information
2002-03-11 by J. Larry Hendry
If I can help in anyway with the construction tips of one
of these for you guys please let me know and I will respond
--LH--
I have helped a couple of guys on the list with some DIY joystick
designs.  To me 1/2 the fun of this whole MOTM experience is the
learning and the satisfaction of doing some of the more simple
things like CV projects on once own.
--TW--
Maybe someday Paul and Larry will offer the official version
--LH--
Paul asked me to build the protp for the MOAJI.  I have been dragging
my feet because it is a later summer release (approximate) and I have
been catching up on building some of my own stuff (and working on some
of my own goodies).  But, it is on the list of stuff to get back on right
away.
--TW--
Or is the Larry design going to come out as an official MOTM controller?
--LH--
Yes, assuming Paul is happy with my work.  In true MOTM fashion, it will
have features not normally fould on sinple joystick interfaces.  So, even
those of use with DIY Joystick interfacses will still want one. :)
Some of the things that have been keeping me busy besides just building my
own stuff:
 - prototype of SKB pop-up case back (goes for metal quotes this week)
 - using up "space for rent" on 830 mixer board (LEDs....)
 - photo albums of 830 and 101 construction (add to website tonight)
 - finishing all docs for 850 breath controller mod (website this week)
 - design and letting of contract for walnut Stooge case (with magic buss)
 - adding tons of new chrome to the Harley for summer fun
Later,
Stooge Larry (quite, but busy)
2002-03-11 by thomas white
Hello gang,
I have completed my 2 new joystick modules for my MOTM system. They are
still prototyped silver and I plan to eventually paint them black and
properly label them with nice black Brother label tape. Sorry if the below
image is too much for your box, but I only want to share my experience and
offer help to anyone who wants to build one of these on their own. The
design is rediculously simple and please understand that I am not an
engineer and I do not endorse the safety of these designs. I found them on
the internet and modified them to my liking, specifically with my MOTM
system in mind. I will share any of my part sources and building tips from
my own experience with anyone who wants them. Maybe I can put it together as
a packet of information on a webpage if the response deems it.
Both joysticks were built for $10-$15 dollars each including the front
panel. Basically sawed a cheap 19" 1u into 2 MOTM 1u's and drilled the
appropriate holes. Very easy and with paint will look decent enough. The
silver natural look is great but very easy to scratch as you can sort of see
in the picture. I have had the IBM model planned forever and actually only
built it after finding that the Joystick project of Larry's is still on the
bench for a while. There are 2 in the picture and lets call them A & B.
Joystick A is on the left with the IBM joystick and Joystick B is the right
with the panel mounted one. Lets start with A:
Scale Pot for (+/-) 0-15v scale depending on the position of the Joystick.
This IBM stick has switches on the bottom to make it free-moving or return
to the center types. I plan to use this mainly as return to center. Each
axis has a fine pot fed by the dual ganged scale pot. I used dual ganged for
panel space (I wanted LEDS).
The LED's are Bi-polar per axis and each axis has a Jack for out. The
Joystick connector is a standard MIDI connector and the cable to the
joystick a (surprise) MIDI cable with one end cut off and re-wired to the
pots inside the stick. If you wanted a 7 conductor wire you could easily add
the 2 trigger switches and jacks in place of panel LEDS or use a larger
panel for more evrything. Scale pot is like global range and fine per axis
allows for smaller bend ranges. Very simple, Very Cool! The IBM joysticks
used to be available at goldmine electronics but they are now sold out.
Shame, I have one I would be willing to selll to the first person with $5.
and shipping. Let me know.
Joystick B: This one is much more simple and has the following features.
Range pot per axis (no fine here but works fine) Switch for polarity, and
jacks out per axis. Much simpler and can only offer (+) or (-) voltages at
any given time. Better for me this way since it does not offer a return to
center feature. I plan to add LED's per axis somewhere above or below the
panel mounted joystick later. The joystick and metal bat handle is available
from MECI.com for less than $2.00 .This module was more like $10 and the IBM
$15.
If I can help in anyway with the construction tips of one of these for you
guys please let me know and I will respond accordingly. I am not offering to
build only tell or show you everything I did in detail. Myabe build, how
much is it worth to you? Take it or leave it.
I am extremely happy with the outcome of my venture and I plan to make more
of a super joystick in the future with aspects similar to the Panel
controller available form Wiard for (gasp) $300. For $30 or so in parts that
seems a little much but then again there is that anodizing that goes on
there and I have no idea what that costs. It would be nice to cut out the
voltage and feed any signal through the joystick like a dual attenuator.
Split a signal and feed it through for joystick controlled pan, CV router
etc. MOTM benefits greatly from controllers like this due to its ENORMOUS
array of inputs and outputs for control and especially all the reversing
attenuators. Maybe someday Paul and Larry will offer the official version
but for now I am glad I spent the $25 on these 2 projects.
Again I am sorry if the attached image is too much, but most people will
understand more if they see it. I have images of the back of the panels and
more panel close up if you want to see, email privately. Would it be
possible to make a small run of panels for these or a similar group "picked
over" version? Or is the Larry design going to come out as an official MOTM
controller? Lets find out, I know some of you must be curious about the old
wammy potential. Enjoy and regards from a MOTM inspired DIY enthusiast!
Thomas White
Send and receive Hotmail on your mobile device: http://mobile.msn.com
Re: JOYSTICK DIY Information
2002-03-11 by Scott Gibbons
Thomas -
It's not possible to distribute file attachments on this list. You'll need
to upload images to the files section at:
http://groups.yahoo.com/group/motm/files/
Your joystick sounds cool, I hope you'll post a picture so we can see it :-)
cheers,
- Scott
Re: [motm] Re: JOYSTICK DIY Information
2002-03-11 by Thomas White
I just posted the diy Joystick images up at Yahoo files page. Some of us can't access yahoo because we joined before yahoo took over. Go join MOTM group there and have zero messages sent to you. This way you can avoid a doubling effect in the mailbox.
Thomas White
Sent: Monday, March 11, 2002 9:08 AM
Subject: FW: [motm] Re: JOYSTICK DIY Information
I didn't get Kris' attachment, but we've sent attachments in the past via
this list... I find that much preferable to that file list, which I can
never get into.
Is this some new Yahoo rule...?
Sent: Monday, 11 March, 2002 12:10 PM
To: motm@yahoogroups.com
Subject: [motm] Re: JOYSTICK DIY Information
Thomas -
cheers,
- Scott
Help with sourcing joysticks
2002-03-12 by James Richardson
I've been inspired by Thomas White's joystick designs to try and put
together something along the same lines for my own system.
Unfortunately, it's nigh on impossible to source an affordable joystick
here in the UK.  Tom's source for cheap joysticks, MECI.com, will only
ship internationally for orders in excess of $50 which equates to about
30 joysticks...  The minimum order in the US is $20 (i.e. about 12
joysticks together with the associated aluminium handle)
Would anyone in the US who is perhaps similarly inspired to put together
a joystick controller (and ideally with a PayPal account for ease of
payment) be willing to submit an order to MECI.com and send some
joysticks over to me here in the UK?
Email privately if able and willing to help.
James Richardson
