Re: ] New MOTM-310 pages at wise guy synth
2002-02-10 by J. Larry Hendry
Too bad there isn't a mod to get rid of that stupid
shape knob and add outputs for each waveform.
Now that there is a uMixer in addtion to the
830 it seems even more stupid :/
--LH--
Well, that's not the words I would have used. Individual saw and pulse outs
would not be a difficult thing as I see it. But, if you were going to mix
them externally, I ask why? The shape control is "basically" a mixer
between the two waveshapes. You would not get anything different by mixing
them externally. There in no internal waveshaping for sine or triangle.
But, if you insist on hacking your's up this looks like it would work
- Remove VR4
- Install a jumper from pin 2 to pin 3 where you removed VR2.
- Add a jack in the hole you removed the VR-4 pot.
- Connect a 470 ohm to 1K resistor from pin 1 where
the VR-4 pot was to the new jack.
Dislaimer: I am not an engineer. I am not qualified to give such advice.
This is my casual observation of a way to hack up a perfectly good MOTM-310
into something ugly without increasing functionality at all. Once complete,
an external mixer is now required to mix the two output shapes. In other
words - Don't do it.
--MM--
although I guess the 310 would make a decent clock.
--LH--
Nice 1U driver for the Blacet Miniwave.... :)
And, I use saw and pulse wave the most anyhow.
