ASR (was: possible micro module?)
2002-01-31 by Tkacs, Ken
I would love to see an MOTM Analog Shift Register. Would it be hard to just take the existing S&H design from the 101 and put it 3 times on a PCB along with a small clock circuit? Seems like it would be a real quickie module. -----Original Message----- From: jhaible@... [mailto:jhaible@...] If you have several S&H's in one module it would only be consequent to chain them like the Serge Analog Shift Register. (I have a circuit for something like that.) Individual Signal inputs and clock inputs for each stage (to use them as separate S&H's), but normalized to a Analogue-Shift-Register chain. jwbarlow@... schrieb: > Sorry to interrupt the current discussion of the pros and cons of schematics. > > I was thinking today how nice it would be to have several more sample and > hold modules in any given system (I think it's an under appreciated and under > utilized module). Though the 101s aren't expensive at all, they only supply > one S/H per module and some elaborate random/noise functions, of which one > probably wouldn't need more than a few in any system. > > What I was thinking was a 1U module with six jacks (S/H in, S/H out, external > pulse in) and 3 knobs (2 S/H attenuators, and internal clock rate) -- two > independent basic S/H units sharing a common clock which would be defeated by > inserting a jack into the external pulse input of each S/H. > > With this module and an 820 one could get the VC sample and hold that I had
> proposed a long time ago. > > JB
