VCO sync
VCO sync
2002-01-28 by sikorsky
hello all,
and now - inspired from something that was posted on Gas Station, i've been
experimenting with trying to alter the sync signal between a pair of VCOs -
even though the signal is either 'on' or 'off' i've had some fun routing
hard sync through a VCA modulated by a second EG
anyone got any other sync tips..?
oh hang on - what about using some S&H to modulate a narrow pulse from a VCO
masquerading as hard sync..?
erm - i might go and try that one, i think it might do something rather
obvious
cheers
paul b
scuttles upstairs...
Re: [motm] VCO sync
2002-01-29 by J. Larry Hendry
PB, I would be most interested in hearing about your wanderings in this
arena.   I love the 300 osc classic hard sync tones.  Sometimes I like to
soft synth too,  The soft sync on the 300 is perhaps not as soft as what I
might like for some applications.  if you uncover methods that produce
varying levels of "grip" so to speak, that would be cool information to
have.
obvious
cheers
paul b
Re: [motm] VCO sync
2002-01-29 by sikorsky
VCO
hello all,
i tried this one - a classic 2 x VCO hard sync combo, into a 440LPF, 440 fm1
modulated by the inverse EG output, except that the hard sync on the 2nd VCO
was controlled by the narrow pulse output of a third VCO. the 3rd VCO was
v/oct modulated by an MOTM101, clocked to the original gate signal, a slew
setting of around 4 was great
i think i must have pre-tuned the frist two VCOs otherwise the is no reason
why it should have sounded so good
another thing would be to PWM a third VCO as sync controller..?
we'll have to see tonight - after i've finished my OMS820
cheers
paul b
[motm] OT: step-down converters for switzerland/germany
2002-01-29 by Aaron Day
hello-
can any of the swiss or german inhabitants on the list tell me what you call
a 220v-110v step down converter auf deutsch?  i have been bashing away at
the conrad.de site for an hour and get nothing but info for DC to DC stuff.
also if anyone can recommend a good brand/model.
danke.
ad
aaron day
m�nzstr 21
berlin 10178
aaron@...
phone |  +49.30.28877760
fax |  +49.30.28877780
cell |  +49.178.7958076
Re: [motm] OT: step-down converters for switzerland/germany
2002-01-30 by jhaible
Look for "Trenntrafo" (that's 230V - 230V) and pick one with
center tapped winding.
JH.
-----Urspr\ufffdngliche Nachricht-----
Von: Aaron Day <aaron@...>
An: <motm@yahoogroups.com>
Gesendet: Dienstag, 29. Januar 2002 19:47
Betreff: [motm] OT: step-down converters for switzerland/germany
hello-
danke.
ad
aaron day
m\ufffdnzstr 21
berlin 10178
aaron@...
