822 and 831 part value changes
2002-01-25 by J. Larry Hendry
While building some 822s, I have found that I could not get an exactly perfect match between the A and B channels. While the error was too small to hear, it caused me to realize that I have not allowed enough slop in the channel matching trimmers to compensate for every possible part tolerance error. So, I am recommending some part value changes for 822 and 831 modules for those that have not yet been built. Now, if you have already built yours and it calibrated fine, DO NOT go back and change it. This modification will not make it any better. However, if you have not built yours yet, or if you ran out of trimmer when matching the channels B to A on the 822 or B & C to A on the 831, then please change these values on your schematic. Also, this reduces the number of resistors that require matching. Here are the changes: For the 831 (4 parts total): Change R27 from 499K to 487K (no longer requires matching) Change R38 from 499K to 487K (no longer requires matching) R16 remains a 499 K but no longer requires matching. Change VR11 from 1K to 20K Change VR12 from 1K to 20K Note, you must change the trimmers and resistors at the same time For the 822 (4 parts total): Change R30 from 402K to 392K (no longer requires matching) Change R31 from 402K to 392K (no longer requires matching) R24 remains a 402 K but no longer requires matching. R25 remains a 402 K but no longer requires matching. Change VR18 from 1K to 20K Change VR19 from 1K to 20K Note, you must change the trimmers and resistors at the same time I will be changing the documentation and parts list for both 822 and 831 on line in a couple of days. Now, if you purchased matched resistor sets from me for your 822 and 831 and are planning these changes, I will be happy to replace the two fixed resistors from that set that changed. You are on your own on the 2 trimmers since I didn't supply them to begin with. Just send me a note that says, "Larry you scumbag, You sold me these resistors and are now changing the value. I want my free replacements." They will magically appear in your mail box. Of course, you have to tell me the total number of 831 and 822 kits you need resistors for. :) Once again, this is not a required change. But, the last two 822s I built had a 0.2% error matching to the "A" channel. Granted, that is very small. But, it was just enough to pi** me off so I made the change. :) Other good news. Mouser now stocks a continuous rotation switch that matches the "large diameter" switch for you 822 builders (for the "STEP" positions). If you are building in a rack and can use the larger diameter switches, you can now purchase a switch that requires no modification. I will add that part number to the parts list when I make the other corrections. If you are using the smaller diameter expensive Electroswitches (required for wood cabinet builders), there is still no one stocking the continuous rotation switches for the "Step" switches. However, I just bought another 50 directly from Electroswitch. So, I will have them for those that want them. Larry Hendry P.S. Allied is selling the LT1013 chips for about 1/2 what Newark is getting for them. I just got some for ~$1.20 each.
