Paul,
I have a Jupiter-4 which, I'm told, is the same design as the 184 but with a 4 voice
synth attached. Tom Morvansky has some mods for the JP4 that allow CV ins and outs
that I have to get done someday... The behavior you describe doesn't match my JP4.
The range of the arpeggio is a function of the octave used. The higher the octave,
the smaller the range. In the top octave, when you hold a single key, you get a 2
note arpeggio. In the next octave down, it is 3 notes, and everything lower is 4
notes.
I hope that helps.
Eric
--- sikorsky <vulture.squadron@...> wrote:
> hello all,
> just been sorting out some bizarre-ness with my new M184 keyboard, so anyone
> out there with one - is the implementation of the arpeggiator totally
> bizarre as well..?
> on mine in the up mode, and down mode there's only one octave on the
> keyboard that will trigger a two note arpeggio, all the other keys just
> trigger a single repeating note. in up & down mode all keys EXCEPT this one
> octave trigger a sequence instead of a single note
> does anyone else get this..?
> cheers
> paul b
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
