FW: [motm] Corel "fixed" ?
2001-12-09 by Tkacs, Ken
Your Postscript travails sound about right... that's the kind of cr*p I run into all the time. I loathe Postscript.
-----Original Message----- From: Paul Schreiber To: MOTM listserv Sent: 12/09/2001 1:06 AM Subject: [motm] Corel "fixed" ? 1) I figured out that the SAVE icon greys-out when you haven't edited the file enough to cause a 'new file' that can be saved. I find this irritating. 2) The printing has to do with having PostScript Level 2 enabled. If 1 or 3, prints. If Level 2, no print. See what I have to deal with just to ship panels? Sheesh! No wonder I'm behind. OK, the uVCF and uMixer panels will be sent off Monday to a new vendor. Hopefully, they will be the same quality as the present panels. They will use Stooge brackets (stainless steel), unpainted. This keeps the cost lower. I will also panel-up the JH WiggleBug LFO and 1U Power Supply (which is looking more like $119 than $99). Paul S. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
