uVCO range poll
uVCO range poll
2001-11-24 by Paul Schreiber
MOTM-310 uVCO is up and running. I am looking at 1 tweak: to compress the COARSE range some from
the MOTM-300.
The MOTM-300 has an extremely wide range for the COARSE knob: at '0' it's about 1 cycle in 8
seconds, and at '10' it's about 150Khz.
I am thinking about 'compressing' it so that the overall range is more useful. This is 1 resistor
value change.
One range I'm looking at is from about 2Hz to 18Khz. The VCO can go lower/higher, this is JUST
the 'no input', free-running range.
The range is like a Slinky: if it goes LOWER, it also goes HIGHER.
So, if I have a 'LFO' type low side, the upper end gets non-useful sooner. So, is 2Hz - 18Khz OK?
Other ranges?
One interesting note is the '5' position is always around 220Hz (set by another resistor). So,
the COARSE resistor can be though of how 'fast' the lower and upper frequencies are reached. Is
it better to have:
a) 10Hz to 10Khz
b) 2Hz to 18Khz
c) 0.5Hz to 30Khz
yawn, burp, Zzzzzzz
Re: [motm] uVCO range poll
2001-11-24 by sikorsky
> c) 0.5Hz to 30Khz
hello all,
i'd say "C" because any auxilliary VCO (such as this) is likely to replace
the main VCOs for such duties as creating beat frequencies, ring modulation
and upper harmonics. i think a lot of upper 'headroom' is essential. there's
also the argument about the uVCO's use as an auxilliary LFO and the need for
lower 'headroom' - but i'm not so bothered about that.
a final thought though - i think if the uVCO coarse (and fine..?) pot
'tracked' the same as the main VCO that would be more intuitive to use,
which i suppose points to a range of 0.125Hz to 150KHz
there's no reason whay the 'cheap option' shouldn't still stande head and
shoulders above the competition in every respect :-)
my 0.02 cents (that euro cents) - shit i've just realised i've a big jar of
assorted european coinage - and it's going to be worthless soon
cheers
paul b
2001-11-24 by bigd@onbuffalo.com
From all I have spoken with about the uVCO, it was being counted on for
auxiliary uses and it would be my thought that it would be a mistake to limit
its range.
Jim
"J. Larry Hendry" wrote:
> I bow to the experience of others.  But, I will comment that while aux uses
> for VCOs are common, for me, the most frequent use will be in the audio
> range.  Therefore, the most important thing to me is accurate tracking in
> the usable audio range.  If all three of these choices are equal, I have no
> preference.  If any is best, then that is my choice.
> Stooge Larry
> From: Paul Schreiber <synth1@...>
> a) 10Hz to 10Khz
> b) 2Hz to 18Khz
> c) 0.5Hz to 30Khz
2001-11-24 by Jeffrey Pontius
> useful. This is 1 resistor value change.
[Caveat: Novice electronics person speaking] If it is *only* a one
resistor substitution, why not include the relevant resistors in the kit
and let the kit builder decide?  Only a small addition to the instructions
with a small table equating resistor value to range would be necessary.
Cost-wise, resistors are inexpensive, and the 'let the builder decide'
approach would allow the flexibility that many customers would prefer (I
am assuming that we will not have 100% agreement on a specific range).
For assembled units, you might want a standard or have, say, two lines on
your order page, one for 'narrow' range and one for 'broad' range
(recognizing that the latter would require a bit more organizational work
on your part).
Jeff
2001-11-24 by J. Larry Hendry
Stooge Larry
a) 10Hz to 10Khz
b) 2Hz to 18Khz
c) 0.5Hz to 30Khz
2001-11-24 by phaeton777@yahoo.com
> I think that 2Hz to 18KHz is a very reasonable compromise for an
VCO. Letting the builder decide on the range is a great idea too, if
it can be easily implemented.
Eiher way, I haven't been able to hear up to 150KHz since that band
Menudo destroyed my hearing back in '80s.
Cheers,
Richard.
2001-11-24 by jwbarlow@aol.com
In a message dated 11/23/01 11:01:32 PM Pacific Standard Time, synth1@... writes:
a) 10Hz to 10Khz
b) 2Hz to 18Khz
c) 0.5Hz to 30Khz
Like Moe, I'd prefer it to operate similar to the 300. But given the choices above, I'd prefer C which seems as it would have the most useful range.
JB
2001-11-24 by Scott Juskiw
For consistency, I think it's best to keep it the same as the 300.
But if you are going to limit the coarse range then I vote to keep it
wide:
>c) 0.5Hz to 30Khz
Scott Juskiw
scott@...
Re: uVCO range poll
2001-11-24 by Eric Frampton
> another resistor). So, the COARSE resistor can be though of how 'fast' the
> lower and upper frequencies are reached. Is it better to have:
> a) 10Hz to 10Khz
> b) 2Hz to 18Khz
> c) 0.5Hz to 30Khz
I vote for the "c" option.
e
2001-11-24 by Dave Hylander
C please.  It would be nice to have the fine range compressed some though,
similar to Larry H's 300 mod.
dave
>it better to have:
>a) 10Hz to 10Khz
>b) 2Hz to 18Khz
>c) 0.5Hz to 30Khz
2001-11-24 by George Kisslak
While I agree that the upper range of the coarse knob (over 30Khz) is not
really that useful and eats up some of the knob range, I would prefer to
keep the 310 adjustments the same as the 300.  If this is not an option,
then I would vote 'C'.
Alternatively...
If the coarse range is determined by only one resistor, then maybe make a
"resistor value-coarse range" chart in the instructions and allow the kit
builder to decide the range.  Maybe this could be done for the 300 as well?
(uh-oh)
Hopefully it will be possible to reduce the range of the fine knob to about
2 semitones via one resistor change, as described in Stooge Larry's 300 mod.
(I've made that mod to my 300s - makes it less touchy when adjusting beat
frequencies.)
See what happens when you ask for input?  ;)
George
> a) 10Hz to 10Khz
> b) 2Hz to 18Khz
> c) 0.5Hz to 30Khz
Re: uVCO range poll
2001-11-24 by Mike Marsh
And if this is possible, then how about a jumper to select the range?
Mike
more
the kit
instructions
necessary.
decide'
prefer (I
range).
lines on
organizational work
> on your part).
> Jeff
2001-11-25 by Mr. Nezumi
I like the idea of having options, but I'm sure
even if Paul doesn't set up the kit that way some
industrial MOTMer or Paul will let everyone know
what values will give what results. If just given
one choice with the kit I would go for:
> c) 0.5Hz to 30Khz
But I'd like to know more about this comment:
How "non-useful"; how "sooner"? Could someone tell
me about the usefulness of HIGH frequencies
(50-150Khz)? I'm sure there is a use above the
hearing threshold, but how high?
Thanx,
Mr. Nezumi
Do You Yahoo!?
Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1
2001-11-25 by Paul Schreiber
Most 'music' is below 8Khz. And 50% of the population can't hear above 15Khz. So, the tradeoff
is: if you want LFO-type speeds at the low range (0 to 2 ticks), you 'run out' of useful audio at
the '7' tick.
Also, I have to pick RN55E resistors (ultra-stable) that my supplier has (will call on Monday). I
think I'll be able to get a value for approx. 1Hz to 24Khz. No, I can't change the pcb for
jumpers.
Re: uVCO range poll
2001-11-25 by Graham Hunter
> c) 0.5Hz to 30Khz
Count me in for (c) as well.  I'd like the widest possible range from
the uVCO, matching the 300 being optimal.
Graham
Do You Yahoo!?
