joystick buffer
2001-11-23 by sikorsky
hello all, i.m just putting together my 19" x 2U utility panel for my skb cases, and i finally decided to gut my old 70's TV game to retrieve the joysticks. so can anyone recommend a simple way to buffer one of these..? - ignoring the motm 850 that is cheers paul b
2001-11-23 by Paul Schreiber
Stooge Larry is designing it as we speak!! It's a separate 1U module, lots of LEDS!!! Paul S. ----- Original Message -----
From: "sikorsky" <vulture.squadron@...> To: "MOTM List" <motm@yahoogroups.com> Sent: Friday, November 23, 2001 2:57 AM Subject: [motm] joystick buffer > hello all, > > i.m just putting together my 19" x 2U utility panel for my skb cases, and i > finally decided to gut my old 70's TV game to retrieve the joysticks. so can > anyone recommend a simple way to buffer one of these..? - ignoring the motm > 850 that is > > cheers > paul b > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
From: J. Larry Hendry <jlarryh@...> > Assuming it does have pots, if you want me to draw a schematic and e-mail it > to you I will. i'd love one if that's okay - i've got too much on my plate at the moment to have the time to work it out myself for instance the 2U interface panel has 28 jacks on it and that's the thinned down version !!! > P.S. I am now working on the MOAJI "mother of all joystick interfaces" 1U > module for Paul. But, I want to keep it quiet on the list until I have the > prototype working. It has 17 LEDs. :) <snicker> hmm, a large quantity of cats escaping from a poorly secured bag springs to mind cheers paul b
2001-11-24 by J. Larry Hendry
From: Paul Schreiber <synth1@...> Stooge Larry is designing it as we speak!! It's a separate 1U module, lots of LEDS!!! --LH-- Since the cat is out of the bag... 2 things to look forward to: 1. If Pizza Hut made one of these, it would be called LED lovers. The prototype will have 17 LEDs the size of the ones on the Miniwave. LED lovers lobby Paul if you want to keep that many. No more than two will be lit at once. 2. While designed for the IBM pot size, it will work without modification with ANY pot size. So, you DIY hackers can use any old surplus joystick you happen to like. Did I mention 17 LEDs ? Stooge Larry
2001-11-24 by thomas white
Put me down for the light show for sure! Thomas White >From: "J. Larry Hendry" <jlarryh@...> >To: "MOTM List" <motm@yahoogroups.com> >Subject: Re: [motm] joystick buffer >Date: Fri, 23 Nov 2001 18:45:15 -0600 > >----- Original Message ----- >From: Paul Schreiber <synth1@...> >Stooge Larry is designing it as we speak!! >It's a separate 1U module, lots of LEDS!!! > >--LH-- >Since the cat is out of the bag... 2 things to look forward to: > >1. If Pizza Hut made one of these, it would be called LED lovers. >The prototype will have 17 LEDs the size of the ones on the Miniwave. >LED lovers lobby Paul if you want to keep that many. No more than >two will be lit at once. > >2. While designed for the IBM pot size, it will work without modification >with ANY pot size. So, you DIY hackers can use any old surplus joystick >you happen to like. > >Did I mention 17 LEDs ? >Stooge Larry > > _________________________________________________________________ Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
