700
2001-11-18 by Mike Marsh
Hello All -
A little while ago there was some discussion about the 700 in audio
mode.  Folks were noticing a 'click' on switching.  I went through
this when I first got the module, and as I remember the thing to be
aware of is that even though there is a brief silence inserted while
switching, if the waveforms are out of sync, a click will happen.
Imagine a sine wave that gets switched as it is heading up, while the
sine wave being switched in is heading down.  The silence is brief so
what you get is:
I have a better picture of this, if anyone wants to see it I'll post
it in the Files section.
This module doesn't morph one wave into another: it simply switches
between the two with a brief silence in the middle. Syncing helps as
does envelope tweaking.  It takes a bit of fiddling but you can get
smotth transitions.  Note that usues different waveforms for A and B
is more difficult.
Mike
Re: 700
Should read: "but you can get SMOOTH transitions.  Note that USING
different waveforms for A and B is more difficult".
Sorry about that...
Mike
>...but you can get
B
> is more difficult.
> Mike
Re: [motm] 700
2001-11-18 by Josue Arias
I think is clearer if you think when editing samples using computer: you\ufffdll
hearf a click sound if you didn\ufffdt cut at zero crossing.
Best Regards,
Josue.
> Hello All -
> what you get is:
> is more difficult.
> Mike
Re: 700
Just so, Josue.  The other picture I have is from a DAW with this
illustrated...
computer: you´ll
> hearf a click sound if you didn´t cut at zero crossing.
> Best Regards,
> Josue.
> > Hello All -
audio
be
while
brief so
> > what you get is:
post
switches
as
get
and B
> > is more difficult.
> > Mike
