Abusing a VCA
Abusing a VCA
2001-11-16 by sucrosemusic@yahoo.com
Ok, so here's the question:
Is a VCA usable for CV as well as audio?  I sort of assumed it worked
for CV... here's where it gets weird
If a VCA can be used for CV, then doesn't that mean I can use it for,
well, just about anything?  Like I could run a small electric lamp
through the VCA, and the signal would adjust the brightness?  Or
adjust the speed of a fan?
Hmm.  If that's the case, what kind of power would be safe to run
through it?  =]
Re: [motm] Abusing a VCA
2001-11-16 by Paul Schreiber
It will work for DC, but only up to say 4ma. Do not use it to adjust your toaster over or model
railroad speed.
To: <motm@yahoogroups.com>
Sent: Thursday, November 15, 2001 11:00 PM
Subject: [motm] Abusing a VCA
> through it?  =]
2001-11-16 by mark@indole.net
>your toaster over or model railroad speed.
I think toasters and model trains use AC, but that's still very good
advice. Besides, there is already a MIDI spec for toasters.
Afaik, you can't run DC through VCA input of a 110 due to the blocking cap,
but you can use the X input with the switch set to DC.
Is the upcoming dual pan/fade VCA (MOTM-130??) AC or DC coupled??
