midi to trigger (pro-kadi)
2001-10-24 by AntonFier@aol.com
hello:
i seem to recall a discussion a week or 2 back regarding midi to trigger
devices and there was talk of the kenton pro-kadi. i looked into one of these
and ended up not buying one because it seemed to me that one had to install
the d-sub like connector to whatever one wanted to trigger. now i know that
this makes sense if one is trying to trigger one unit (say a tr-808) but can
this unit be used to trigger say....several modules ? i was unable to figure
out how. i hope i'm wrong. thanks in advance.
regards,
anton
Re: [motm] midi to trigger (pro-kadi)
2001-10-24 by ivancu@aol.com
In a message dated 10/24/01 7:08:36 AM, AntonFier@... writes:
<< kenton pro-kadi. i looked into one of these
the d-sub like connector to whatever one wanted to trigger >>
The D-Sub connector is merely an economical way of having a lot of channels
of triggers on one connector.  You can make or buy a cable that has a D-Sub
on one end and then a fanout to 1/4" phone plugs (or any other connector) on
the other end to plug into whatever combination of gear you want.  For
example, you could plug a few channels into a Simmons drum brain, and then
plug the rest of them into your MOTM.
Ivan
