Index last updated: 2026-04-03 18:09 UTC
SKB pop up power supply - WAS : [motm] Re: Power supply question (was: More Useless MOTM trivia)
2001-10-17 by J. Larry Hendry
> So, how does one slap a power supply into
> a SKB pop-up case?  And I mean so
> that it's nestled inside, not on the racks.
> phew, erm - don't know
hey chaps, i wonder if larry knows
larry   larry..?   are you there..?
Well, after you confised me with that other Stooge, I had to go hide.
Actually, Paul and I were discussing this again over the weekend.
Some of you mat remember we discussed using the bottom two rows left over in
the SKB rack for power supply and some other goodies.  So, let's just see
what people think.  I'll start out by shraring my thinking and admit right
off the bat that I am fully NOT qualified to lead the discussion, since I
don't do the pop up thing.  So, you guys pipe up and tell me I'm full of
stuff.  I don't mind.  Really....
Here was the intiial thought.  Two different panels available 19" rack
standard 2 U high.  So, they fit in the left over part of the SKB pop up
after you fill two rows with modules.
Panel # 1, has the power supply.  Same supply used in the MOTM-900. It has a
power connector in back for modules, just like the current MOTM-900.
However, it also connects to a 4 conductor "speak on" connector that is
wired for power supply connection to the next cabinet.  Then the left over
space has multiples.
So the front is power switch, power cord, external cabinet power connector,
and a group of multiples.
Panel # 2 is for the cabinet without a power supply.  It has the speak on
connector to get power from the other cabinet.  It also has a grouping of
multiples and has room for one standard MOTM module sideways.  Now, I
thought the utility module that everyone would want / need would be the
mixer.  It woudl be the exact same layout as the current mixer.  The basic
difference is the screen is sideways so everything reads right.  The panel
coudl come with or without the mixer electronics and such.  so, if you
already had a mixer, you could unbolt it from the standard panel, turn it
sideways and bolt it right to the 19" rack panel.
OK.  Those are my stupid ideas.   You guys come up with something better.
And hurry up.  Paul wants it for NAMM.  :)
Larry the real stooge.
2001-11-21 by pacific202@yahoo.com
> Panel # 1, has the power supply.  Same supply used in the MOTM-900. >
> speak on connector to get power from the other cabinet.
I'm using an SKB mixer case, am about to expand into my second case,
and would LOVE to get something like this.
One problem - I'm looking at getting an Expressionist and wouldn't
know where to put it.  Maybe instead of making panel #2 with a slot
for a module it could just be a 1ru high panel with room for the cv
converter?
Graham
Re: SKB pop up power supply - WAS : [motm] Re: Power supply question (was: More Usel
2001-11-21 by sikorsky
> converter?
hello all,
i'm just about to go SKB mixer case so that i can MOTM at gigs, the way i've
planned it each case is powered by a 500mA RS supply. i'm building a pair of
2U panels, the power distribution pcb fits sideways along this, with room
for some mults, selector switches and tie lines. the RS supply will be
mounted in an external box
cheers
paul b
(having sold his MS10 to 'the devil' - whomever that maybe)
The Verbization of MOTM - WAS: SKB pop up power supply
2001-11-22 by alt-mode
It had to happen sooner or later that someone would make MOTM into a verb... ;)
   Eric
Do You Yahoo!?
Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1
