Seq Development Environment
1999-08-27 by Paul Schreiber
Quick thoughts.
1) I plan to code in assembler, because
a) the assembler is *FREE*
b) the C compiler is $800
c) I have written over 600,000 lines of 8051 assembler code and 0 lines of C
code
d) I have *already written* 1/5th of the Seq code 1.0 already
2) The assembler code source will be posted to *encourage* hacking. People
not hacking the code
will be made fun of :) (Hack #1: have your name scroll across the display at
power-up).
3) Yes, you can turn it into a
a) ADADRSRDDARDR.... EG
b) LFO
c) MIDI-2-CV
d) Sampler (!!?! heee hee)
I plan to license the Keil Software (www.keil.com) Rom-based debugger. This
is a ~3K
program that is in every Seq. It talks to a serial port, and to a W95-based
program. This program
allows you to
a) download the assembled code (Intel HEX format)
b) single-step it
c) disassemble it
d) run to a breakpoint
e) dump register & memory contents
So, you can find bugs pretty easily *without* a decicated "evaluation board"
or "ROM emulator".
code
power-up).
b) LFO
c) MIDI-2-CV
is a ~3K
allows you to
b) single-step it
c) disassemble it
or "ROM emulator".
