LIN - LAG - LOG
LIN - LAG - LOG
2001-09-01 by jpotter@it.rjf.com
OK - first, say that 12 times fast... --Out loud.
I was just playing around w/ a simple 5 Step atonal sequence
generated by a Encore UEG.
UEG into 820 Lag into the FM1 input of a 300 VCO and out.
Anyway, what's interesting about this patch is the modifying of the
LAG Up, Down, and LIN/LOG controls.  What is really cool is that you
can even change the UP/DOWN LIN/LOG controls in the first place but
what would be extremely cool is if you could control the LIN/LOG
settings of the UP/DOWN legs independently so, for example, you could
run a square wave through it and get a triangle with a Linear Up leg
and a LOG Down leg - or vice-versa.
Tony - Just wondering, is this one of the intended set of controls on
the 820 Companion module?
JP
By the way, look at the synergy of an open system - Encore, MOTM,
Oakley.  Just run it through a Blacet Time Machine, and the dry OSC
and delay output through a DIY mixer and you're golden.  One of the
big pluses of a standard platform and a big reason why I chose MOTM.
