Finished all bench testing of the MOTM-320 VC LFO prototype tonite.
Will start CAD cycle (schematic capture, B.O.M., pcb placement, pcb layout)
tomorrow.
Again: this isn't designed for a VCO replacement, but you can mess around in
the <2Khz
area. It has no HF track, and there is no low Rbe, matched pair (there is a
tempco resistor).
Kit is about a 7 on the complex scale: many resistors and about 15 (!)
discrete NPN/PNP/FETs
(recall this is loosly based on the VCS-3).
On the low end: I got 1 cycle in about 18 minutes with a cheesy cap.
Will keep you posted!
