midi/cv question, part 2
2001-08-02 by David Shoemaker
Hi again,
I'm still investigating various midi/cv options.  Thanks to those of you who
already responded with help in this regard.
Has anyone built or used the following:
PAIA 9700k midi2cv8
or
Oakley mididac2
Any feedback on these two converters as potential choices to drive an MOTM
system?
David
Re: [motm] midi/cv question, part 2
2001-08-02 by sikorsky
> Oakley mididac2
hello all
hello david
i've an original oakley mididac which has been my main convertor ever since
i built it
i think one of the major strength's of the oakley is the motm compatible
panel layout, and the plug-in-and-play ness of it - for instance you have
velocity cv on a jack without any programming
so as an 'installed' controller for your motm, i think it's a good choice -
if you want to go polyphonic, then i think the concensus of opinion tips in
favour of the encore expressionist, also the mididac doesn't convert Hz/V ie
Yamaha CD and Korg MS series synths, if you're after something small yet
versatile, then the Kenton Pro-One is very good
cheers
paul b
very hung over...
