110 VCA/RM Troubleshooting
2001-07-25 by jpotter@it.rjf.com
Finished putting together a 110 late last evening (maybe that's the
problem).
The RingMod part works fine.  I can use the X & Y in and get audio at
out at about the same level as it goes in.
My problem seems to be with the VCA section.  I plug audio in but
only get faint audio out (with the Gain all the way up).  It is
working but seems to greatly attenuate the source - if I turn the
mixer way up and sweep the gain on the VCA counterclockwise I can
hear it's effect.
Don't know if this is good/bad/otherwise but if I touch the very tip
of a cord to either out on the 110 I pick up a radio station - I
don't know if that means something isn't grounded correctly (???)
I've checked all the polarity sensitive components and all are in the
right orientation.
I've checked the resistors and most of the caps several times and
everything is OK there.  Haven't triple checked the axial caps
(printing is really small so I thought I'd get a magnifying glass to
verify) but I'm pretty sure they're correct.
I'm going to double check for obvious shorts but checked several
times during construction and feel fairly confident about that.
Any ideas?
John
PS - the CEM chip doesn't sit absolutely flat on the socket should
it?  I had to pinch the legs in to get it to fit in the socket and
it's slightly raised (but inserted all the way in to where the legs
flair out).
Re: [motm] 110 VCA/RM Troubleshooting
2001-07-25 by bleeped
> hear it's effect.
i had the opposite problem when i built mine: the ring mod woudln't work.
after much head scratching and circuitboard-peering, i noticed the 3330
was sort of off kilter. i reseated it and ring modulated crap all through
the night... another feather in the cap of the "sockets suck" argument.
ooh. can't help you there...
> flair out).
oh... i didn't see that. this is probably definitely your problem.
bleep(probably definitely).
out.
RE: [motm] 110 VCA/RM Troubleshooting
2001-07-25 by John Potter
So should the CEM chip sit absolutely flat on the socket?
Mine sticks up by maybe 1/2-3/4 the thickness of a dime.  Anybody else have
to bend the legs in a little bit to get it in.  W/O doing that there was
absolutely no way it was going in by itself.
JP
Sent: Wednesday, July 25, 2001 3:31 PM
To: jpotter@...
Cc: motm@yahoogroups.com
Subject: Re: [motm] 110 VCA/RM Troubleshooting
> hear it's effect.
> flair out).
out.
i can't recall how far above the socket the bottom of the chip is, if any
at all. my problem was that the chip was in all the way on one side, but
not the other. it was seated crooked. bending the legs is fine, i think,
as long as they make full contact with the socket. try to work the chip in
a little farther by alternately pressing on each of the ends of the chip.
i hope this helps!
bleep.
out.
2001-07-25 by George Kisslak
> flair out).
I believe the chip should go most of the way in - in any case it should sit
evenly all around.  It's a very tight socket, and it's really easy to fold a
leg and *not* notice it.  I've had consistently good results by using a chip
insertion tool that has a grounding lug for safety.  It forms the legs
nicely and also allows for more evenly distributed insertion force.  I
actually use this tool for all 8/14/16-pin ICs regardless if they're going
into a socket or not.  Luckily, I haven't needed a puller yet.  Thanks go to
Paul for not socketing most of the chips!
Cheers,
George
