I notice that
>on the MOTM-420s' the sine out on self oscillation
>sounds more square-like than the original MS stuff
>which You may or may not want , maybe I'm doing
>something wrong ? any ideas - anybody?
Be sure that you don't have the RES set to 10. Rather, set it
for the *onset* of resonance (about 8.5 on my system, where I set
the trim pot).
At resonance onset, the sine is the most pure. As you increase the RES pot,
it will "square up" slightly due to the resistor/cap/OTA gains being not
matched perfectly.
Also, remember you will be driving a signal about 6V pk-pk out. This is 6
times larger than
a "standard output" and the 'distortion' may be in your mixer/preamp/amp,
not the MOTM
itself.
