re:desoldering tips
2001-04-23 by phaeton777@yahoo.com
Hi, My advice-and this is gonna hurt-is to sacrifice the ICs to save the PCB. I have repaired thousands of PCBs and the fact of the matter is that the ICs are replaceable, but the PCB is not. Also by the time you've removed the IC it's usually toasted from all the prolonged heating, and you risk having the traces peel loose from the PCB from heat exposure-if that happens you're toast. In addition, if you manage to remove the IC without damaging the PCB, the only way to know that the IC is OK is to resolder it into the circuit(correct alignment this time;). If it turns out that the IC is damaged then you're back to square one-and this time you WILL damage the PCB by desoldering again. I know it sucks but trust me when I tell that this is the best way: 1. Cut all the IC leads close to the body of the IC. 2. Remove legless IC body. 3. Lift each IC leg out with a pair of tweezers as you heat the solder pad with a small-tipped solder iron. Sometimes it helps to re- wet the pad by adding a small amount of fresh solder. 4. When all legs are removed use solder-wick, NOT SUCKER!, to remove the solder from the through-holes. For MOTM PCBs the blue or green size of MG chemicals solder wick is best. Cutting the wick at a sharp angle helps to squeeze it into the through holes. 5. Buy new ICs, then send girlfriend/wife/kids to store with credit card and try again. Best of luck! Richard.
