Desoldering tips on ICs - The Big Oops
2001-04-23 by bruce@sigalarm.com
Well, I need some advice.  First, let me give some. Never let your
dear wife distract you while building something complicated.
That being said.  In my current build project, MOTM 440 Filter, I have
managed to get all of the 2220 and 2210 IC's backwards.
I have managed to get one of them unsoldered after about an hours
worth of work. I have a good solder sucker, but it seems minute
amounts of solder are still hanging around causing the chip to adhere
to the board.
Anyone have and good suggestions on how to get the little buggers off?
Bruce
Re: [motm] Desoldering tips on ICs - The Big Oops
2001-04-23 by jwbarlow@aol.com
In a message dated 4/22/2001 4:11:00 PM, bruce@... writes:
>to the board.
If you have one of those sucker bulbs that one is to use in conjunction with
a soldering iron, you are wasting your time -- it will never work (why do you
think they call them "suckers")!
I got one of those "deluxe" Radio Shack Desoldering Irons (a bulb and iron in
the same unit), I think it cost me about $8.00. I have had a good bit of
success with this tool, and real desoldering stations cost real money.
The bad news is that the through plated holes are really good at allowing the
solder to pass from one side of the board to the other -- making it a bear to
desolder. Take your time with those SSM ICs since they will be hard to get if
you screw one up. I'd suggest doing one or two pins per IC, then walk away
for a few minutes.
Good luck!
JB
2001-04-23 by elhardt@aol.com
bruce@... writes:
>>I have managed to get one of them unsoldered after about an hours  worth of
work. I have a good solder sucker, but it seems minute amounts of solder are
still hanging around causing the chip to adhere to the board.
Anyone have and good suggestions on how to get the little buggers off?<<
I don't know if solder wick will help here.  I sometimes have to use both
solder wick and a solder sucker depending on the circumstances.  However, I
had to remove two regulators recently and even just getting one of those
simple devices out was a 10 minute ordeal with me worrying that I'd start
pulling the traces off the PCB in the process.  I just said to hell with it,
clipped out the second one and bought new replacements in my last Mouser
order.  Sometimes it's easier to do that if you are dealing with inexpensive
parts.
-Elhardt
Re: Desoldering tips on ICs - The Big Oops
Just a bit of an update.  It took time and determination, but I got
them all out, destroying only one of the upper pads in the process.
Word to the wise, it takes a long time to take these out. It would
have been far easier to do it right the first time... check and check
again.
Anyhow, upper pad was repaird, they are all back in.  I caught this
just moments after finishing the IC soldering stage, so I will wire it
up tomorrow and hopefully have a lovely SSM 2040 clone tomorrow.
Thanks for all the suggestions.
Bruce
2001-04-23 by Tony Allgood
Hi all,
The SSMs are eight pin DILs. Go get a bit for your iron that heats all
eight pins up at the same time. Most of the big mail order guys do one.
You then pull the chip out with a chip extractor or a little
screwdriver. It may be cheaper than buying a load of SSM2220/2210.
The way I do it, and I have never had to cut a 8 pin DIL off at the
body, is to heat one row of the legs at once with a normal 5mm bit. Use
lots of fresh solder smother the pads in solder, you can always soak it
up later. Prise the IC up with a screwdriver. Then do the other side.
Spend only 10 seconds or so to do each side to keep the temp of the IC
down.
For a 14 pin DIL, I would probably go for the cut legs method.
OR... only for the very brave/stupid, ie. not me :-) Gas blow lamp on
'fine' 20mm wide flame. 2 second burst on the back of the board aiming
at the IC. Then immediately bang the board onto the bench and the IC
drops out. I never tried it, but I had a colleague who dumpster dived
computer boards to rescue ICs who did this regularly.
Tony Allgood  Penrith, Cumbria, England
Oakley Modular Synth and TB3030:
www.techrepairs.freeserve.co.uk/projects.htm
My music: www.mp3.com/taklamakan
2001-04-23 by mark@indole.net
>to the board.
I use Chem-Wick.  It's about $3 a roll and lasts a very long time.  I try
not to solder IC's in backwards, so I've used the same free sample I got
back in the mid-80's when Chemtronics first introduced it :)
I have a Paladin solder sucker, but it isn't very useful for PCB's -- it's
good for big stuff.
You can also try using a piece of braided shield from a coaxial cable.  Cut
a little piece about 1/4" square and hold it next to the joint with your
iron.  The solder should wick onto the braid.  Of course you have to do
this for each pin.
They also sell spring loaded IC extractors -- I've never used one.  I use
this thing that looks like a pair of ice tongs that came with a ROM upgrade.
Then again, Paul doesn't think my soldering is very good -- so maybe you
shouldn't listen to me :)
