Oakley 410 & 820 Assist Modules
2001-04-02 by Tentochi
From the Oakley ML.
410 and 820 assist modules.
--Shemp
Sent: Monday, April 02, 2001 2:39 PM
>What were the details on the 2 MOTM piggyback modules aagin ?
OMS-410
Triple reversible attenuators to drive each vactrol element of the
MOTM-410
VCA controlled outputs of each of the MOTM's LFOs. Sinewave outputs.
Audio mixer to create a stereo output from the three separate outputs.
Pad switch
Invertor amplifier.
If you have a look at my version, you will see that I have not included
the pad switch or the invertor output on the actual front panel. If you
wanted to use all the features on this board, you would need 2U panel
space. I will put up some panel variations based on what was talked
about a few weeks ago.
Actaully, you can do allsorts of things with this PCB. You could even
make a triple reversible attenuator with a higher input resistance than
the multimix with this board. You could even make a simple dual VCA
board too. Its a right little building block.
OMS-820
VC-LFO function
VC-AD and ASR functions with repeat
and other things I haven't thought of yet :-)
Cheers,
Tony
