Index last updated: 2026-04-03 18:09 UTC
gaps in MOTM cabinets
2001-03-21 by drq48423@yahoo.com
I just KNOW somebody here has already dealt with this problem, so here
it goes...
Here I am, doing the math for a 24U cabinet. I just got my order for
300 zinc hex drive inserts from McMaster.com (they're cheap AND fast
too!) and I'm ready to go. 24U = 42 inches internal, check. With 3/4
in. wood (of a type yet to be determined) we get an external length of
42 + 1 and 1/2 in. = 43 1/2 inches, check. And two 1/2 in. thick pine
strips on the inside horizontal,  to hold the inserts (huh...huh...I
said inserts ;-)
Now comes the tricky part; figuring the *slop factor* (MOTM-spec is
0.015 in. or, 1/64 in.). If we assume 24 *slop gaps*, then 24 times 1/
64 in. = 24/64 in. = 3/8 inch! Yikes! Can this be right? That's a lot
of slop. So, should I add 3/8 in. to the overall length? I was planning
to set the inserts by setting a '800 in the completed box, mark the
holes, drill and set the inserts, bolt the '800 down, insert 1/64 in.
spacer between it and a blank 1U panel, mark the holes, ect. so I'll
need to know the correct length beforehand. I see there's enough play
in the mounting holes on the panels to give me some wiggle room, so I
guess my question is, am I being too anal about this *slop factor*
stuff?
Somebody mentioned something about plastic strips for use as visual
separators between modules (plastistruct?), ala Moog. I need to look
into that and I'm too lazy to look it up in the archive ;-)
Chuck
being anal AND lazy
Re: gaps in MOTM cabinets
2001-03-21 by mate_stubb@yahoo.com
There should be no added slop in your cabinet design. The panels are
mounted on exact 1U increments. 1U is exactly 1.75". The gaps between
2 panels happens because the panels are cut about 0.025" narrower
than the full width.
Now if you want to add separators, all bets are off. You'll have to
add the thickness of the separators in and spread the holes out. But
it will still be a problem between 1U and 2U modules, because there
will be twice the thickness of separators to fit 2 1U panels into a
width that formerly held a single 2U panel.
For this reason, I don't think separators that fit over the ends and
spread the modules are practical. You can't spread the holes that
hold a 2U panel, and those holes won't be wide enough to deal with
the extra thickness of 2 1U modules. So you would end up with a cab
that couldn't freely interchange the positions of 1U and 2U modules,
and what's modular about that?
Moe
here
> it goes...
for
fast
3/4
of
pine
(huh...huh...I
> said inserts ;-)
1/
lot
planning
in.
I'll
play
I
> stuff?
look
> Chuck
> being anal AND lazy
Re: [motm] gaps in MOTM cabinets
2001-03-21 by J. Larry Hendry
As I see it,
The slop is subtracted from and not added to the full 1U / 2U panel width.
1U = 1.75 = .015 = 1.735   2U = 3.50 - 0.15 = 3.485
So, if you figure your cabinets on full 24 U spaces (42 inches inside) you
have already included the slop.
Larry H
2001-03-22 by drq48423@yahoo.com
--- In motm@y..., "J. Larry Hendry" <jlarryh@i...> wrote:
Thanx, Stooges. Yoda-like, backward thinking is me.
Chuck
wiring his brain to a reversing attenuator
> From: <drq48423@y...>
> As I see it,
> Larry H
