One more thing
2001-03-20 by J. Larry Hendry
The metal test panels are going to you in the mail tomorrow. After you look them over, I need them back. You will find three dimples in each. Those are what are called bumps test to check the hardness of the finish. They were 20, 50 , and 70 lbs bumps. You can see what they did to the metal. The front side paint was not damaged. Only that on the back (really the front) that was stretched out. The finish is very durable. Larry
----- Original Message ----- From: <mate_stubb@...> To: <motm@yahoogroups.com> Sent: Monday, March 19, 2001 11:09 PM Subject: [motm] Re: waaaay ot--hot wires When I used to rock n' roll with a band which used a lot of pyro, we built flash pots which were nothing more than 2 screw terminals with an AC cord attached. Instead of buying special trigger wire, we would make our own by taking zip wire and unravelling it to use a single strand of thin copper. The 120v was enough to pop it every time, without blowing breakers. Of course, you can fry yourself if you wire it up and it's still plugged in. Dangerous! Moe --- In motm@y..., "J. Larry Hendry" <jlarryh@i...> wrote: > You want nicrome wire. It used to be sold a lot for model rocket engine igniters. Of course, you could just use model rocket engine igniters. Check your hobby shop.. You can light them off 3 or 4 "D" cells quite easily. I never tried AA, but seems reasonable, just not as many times. :) > Larry H > ----- Original Message ----- > From: klem klemmingberg > To: motm@y... > Sent: Monday, March 19, 2001 10:27 PM > Subject: [motm] waaaay ot--hot wires > > > Howdy-- > I want to ignite flash paper electrically--from some aa batteries. I'm thinking > very thin wire would heat up well, but i'm not sure if there's some trick to getting wire > extra hot. Or is there some sort of electronic component that would do the trick for me? > > Please reply off list. > > tomr > (keeping the OT in MOTM) > > Yahoo! Groups Sponsor > > > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
