MOTM inspired
2001-03-12 by josephcasbarian@email.com
Hi group, A few of you know me, i'm a naive MOTM enthusist and an Artist. I'm wishing to do an installation, using my MOTM along with projected light. I want to control projections of Red, Blue, and Green using 320s, to produce patturns of color at different rates. (the beautiful sound of 300s will be heard as well) I don't have a clue how to do this. If you have any suggestions, please email me privatly. Thanks, Joseph Casbarian
2001-03-12 by Tentochi
Welcome aboard! An easy way to achieve the effect you are looking for is to glue a small piece (or small pieces) of mirror to a speaker. Next, direct an intense beam of light (up through the strength of a laser beam) at the mirror (please take all appropriate safety measure for yourself and you patrons). Finally, send a normal amplified sound to the speaker. And instant, cool Lisa Jousse-like patterns on the wall. You will need to experiment to get an effect you are happy with for your installation. Cheers! Shemp
> A few of you know me, i'm a naive MOTM enthusist and an Artist. I'm > wishing to do an installation, using my MOTM along with projected > light. I want to control projections of Red, Blue, and Green using > 320s, to produce patturns of color at different rates. (the beautiful > sound of 300s will be heard as well) > > I don't have a clue how to do this. If you have any suggestions, > please email me privatly. > > Thanks, > Joseph Casbarian
2001-03-12 by sikorsky
From: <josephcasbarian@...> > A few of you know me, i'm a naive MOTM enthusist and an Artist. I'm > wishing to do an installation, using my MOTM along with projected > light. I want to control projections of Red, Blue, and Green using > 320s, to produce patturns of color at different rates. (the beautiful > sound of 300s will be heard as well) hello all, you'd be looking at some kind of relay connected to the pulse output of the 320s. there are companies that do this kind of kit for very little money here in the UK, so there's bound to be some available in the States - just check out digikey, mouser etc etc. the output of the 320 will flip a relay to switch in the mains supply to a lamp - is this what you're after..? i think if you have the option, use a relay that is optically isolated - ie there is no direct electrical connection between your precious MOTM and those nasty lightbulbs. i think one company that does stuff like this is Vellemann, though i don't have a Maplin catalogue here to check - they used to also do gigantic LED ladder PPM kits, but with the LEDs replaced by mains powered lightbulbs - cool... now all you have to do is figure out how to use your 320s to trigger a pair of Kodak SAV2050 projectors and you'll be sorted (i haven't worked this one out yet...) cheers paul b
2001-03-12 by KA4HJH
>Welcome aboard! An easy way to achieve the effect you are looking for is to >glue a small piece (or small pieces) of mirror to a speaker. Next, direct >an intense beam of light (up through the strength of a laser beam) at the >mirror (please take all appropriate safety measure for yourself and you >patrons). Finally, send a normal amplified sound to the speaker. And >instant, cool Lisa Jousse-like patterns on the wall. You will need to >experiment to get an effect you are happy with for your installation. Here are some inexpensive gadgets of this type: http://www.mi-lasers.com/laserlight.html I have the GAL-2 myself. Only needs a small amp, but you pretty much have to have a 5-10 mW laser for it to look decent. -- Terry Bowman, KA4HJH "The Mac Doctor"
