2001-03-10 by J. Larry Hendry
Paul,
There is a lengthy discussion of this subject at:
http://24.12.85.234/larry.switches.htm
The slimline part numbers for the switches that you need are there. The
only switches I found to work are the ones made my Electroswitch. If you
cannot find them in the UK, I can get you the "adjustable stop" (-A) version
here in the USA and send them with your upcoming panels order. I got them
from Allied. I could not find the full rotation switch anywhere (-C). So,
I purchased them directly from Electroswitch. I don't have any of those
left. However, Dave Hylander wrote some very fine instructions on how to
modify both the standard and slimline switches for full rotation. You will
find those modification instructions also on my web site.
Good luck. Let me know if I can help you with getting what you need.
To: <motm@yahoogroups.com>
Sent: Saturday, March 10, 2001 12:42 PM
Subject: [motm] 822 & 831 question
hello all,
i just realised my 822 & 831 don't fit in my cabinet
do any of the UK chaps out there have a part number for a slimline
replacement switch..?
cheers
paul b
