Running a lead of my sound to........
2001-02-26 by bigd@buffalo.com
.......my scope and tuner permantly.  Is there a krafty (pun
intended) way of doing this without using a mult for my VCA
Thx in Advance
jim
Re: [motm] Running a lead of my sound to........
2001-02-26 by jwbarlow@aol.com
In a message dated 2/25/2001 4:10:25 PM, bigd@... writes:
Maybe a Y cord or two? Maybe make your own custom cord with several ends?
BTW, I wouldn't run my (chromatic) tuner out of my VCA. I have a dedicated
cord long enough to reach all the VCOs (and VCFs if needed), and just leave
that cord dangling from the tuner input jack until I want to check a
particular VCO, then use one of the open outputs on the VCO (preferably a
sine or tri). One advantage of this is that you can fine tune the VCOs (if
you're careful) without having to listen to them.
For non-critical visual fun, I guess I'd use a Y cord to do a similar thing
with a scope, once I figured out what I wanted to look at.
JB
