[motm] switch destruction -> IC soldering
2001-02-23 by elhardt@aol.com
jwbarlow@... writes: >>Wasn't it you that was having trouble with a soldering iron continually burning out tips maybe a year ago? Maybe this problem is related to that (over voltage or something similar).<< Yep, that was me. But I bought a Weller solder station based on people's recommendations and that is what I used to build about 2/3 of my modules. It works beautifully and the tips don't disintegrate. But it still causes those problems when soldering to switches. I keep the temperature dial set just to the right of the 12:00 position. I don't know what temperature that equates to. But I have learned how to solder the switches to prevent the problems now. When I solder IC's I usually just solder a couple of pins, say upper left and lower right on one IC, then move to the next IC. Then I circle back and do another couple of pins. This helps prevent them from getting too hot. -Elhardt
