Wiard Mini-Wave 1202
2001-02-22 by Tentochi
Here is some info about the Wiard Mini-Wave 1202. For those of you who don't know, John Blacet of Blacet Research (http://www.blacet.com) is doing an MOTM/DIY version of the Wiard Mini-Wave 1202. I believe only about 10 of the Mini-Wave were sold by Wiard (http://www.wiard.com) and it looks like Wiard is on its way of going out of business. They will not sell individual modules to new buyers--only complete systems. And they only have a few complete systems left. The Mini-Wave is also at the heart of the Wiard Waveform City module which included other functionality such as EG, VCA and mult. The Mini-Wave has a 400 kHz A/D converter. I belief someone here said Wiard used the Digisound chip in its design. It also contains a 64k EPROM. (Does the Mini-Wave morph between sounds as on the PPGs and Waldorfs?) The Wiard Mini-Wave sold for $199 + $10(S&H) assembled. The Waveform City sells for $549. I hope that John Blacet uses a standard MOTM-sized PCB, standard mounting hole locations, ZIF EPROM socket and a standard MOTM power connector in his design. I am assuming that Dave and Larry will probably be doing a run of Mini-Wave FPs in the future... Here is the original Mini-Wave manual which includes a variety of MP3s and pictures. http://www.wiard.com/Grants%201200/MiniWave/MiniManual.html Here are pics of most of the 256 waves. This link is also included in the above manual, but it is so important that I wanted to separate it out. Some of the waves include: square wave compression, Votrox SC-01 voder chip, binary rate multiplier (CD4098), historic non-linear transforms, custom waves from Darwin Grosse, Digisound VCDO, harmonic series and quantization scales. http://www.wiard.com/Grants%201200/MiniWave/MiniWave_Manual.pdf Here is the Wiard module that is based on the Mini-Wave. http://www.wiard.com/modular/waveform_city/waveform_city.html Here is a brief description of traditional wavetable synthesis from a PPG user's site. http://www.wavesynth.com/whatis.htm Here are three pics from David Bradley's MOTMized Mini-Wave. http://motm.retrosynth.com/moe_stuff/Motmized_Miniwave/miniwave_front.jpg http://motm.retrosynth.com/moe_stuff/Motmized_Miniwave/miniwave_left.jpg http://motm.retrosynth.com/moe_stuff/Motmized_Miniwave/miniwave_right.jpg Cheers! Shemp
