Re: [motm] Arm fatigue
2001-02-21 by sikorsky
> . The worst problem I have had is trying to "tune" an analog sequencer row up high. That > can tire out your arms quickly! So, if you use an analog sequencer a lot, don't > copy the Moog modular model with the sequencer way up on top! hello all, i don't know if this is too obvious, or not applicable to Eric's cabinet, but i have my filters on the top row, making the Frequency control well above head high, when mucking around with manual filter sweeps, i use my thumb & index finger to tweak, while the other three fingers rest ontop of the cabinet... conversely, i currently have my UEG in the bottom row, which has proved to be a real pain, especially with those small knobs just my tuppence in the pot there cheers paul b
