New Oakley module proposals + more
2001-02-15 by Tentochi
Sorry for the duplication for those of you on the Oakley ML. This is some info about modules that Tony Allgood might be doing in the MOTM format. I wish he would have posted this one to both lists. Excellent stuff IMOVHO. I am into using switches as opposed to removing resistors on the 410 rather than "permanently" modifying it. Now if Tony and Larry and Moe can get the FP machine fired up for the next batch... Perhaps Tony could even sell Stooge FPs??????? And yes, I have several modules on the drawing board (actually a stack of napkins) so I won't be left out of the Stooge aftermarket product movement sweeping the globe! I will put out some questionnaires for features in the next couple of days. --Shemp (slight editing of Tony's original text by me) ------------------------------------------------------------------------ SmallStone <- lots of requests WalshBank Filter MIDI-CV Converters (see below) MOTM-410 companion module MOTM-820 companion module The last two, I have been thinking about for the last couple of months. I was inspired by the little Oscillator companion module for Roger Arrick's Synth.com VCO. So the idea is to have individual VC inputs for the three Vactrol elements in the 410. The 410's VC-LFO outputs available separately, and a stereo output of the three filters. You will need a 410 to use this module, and you will have to remove some resistors, but no track cuts or anything else. The 820 companion, will allow you to create a VC-LFO from it with variable waveshape and sync to another LFO. Single or multiple shot outputs too. Again, you will need an 820 to make the best use of this module. No track cuts or resistor changes I think. Both modules will take the form of 1U and will need to sit next to the 'mother' module. The two will be connected by a 0.1" Molex connector. While this is going on... er, I will try to get a WalshBank set up and ready to demo. but this is biggy and will take a lot of time and money to get together so I want to spread the burden of time over a longer period. I still hope to get the MIDIDAC-2 and TB-DAC MIDI-CV convertors done by April. The first has actually been done and is ready to go to the PCB shop. Oh and Paul gives his blessing. :-) Tony
