Panel divider graphics
1999-07-19 by Dave Bradley
Well, over the weekend I put white borders on the vertical edges of all my
modules. I used 1/8" ChartPak graphics tape as has been mentioned earlier on
this list.
The visual difference is stunning. It's not as pretty as aluminum separators
ala Moog, but it looks quite nice, and you can find a module in the middle
of a big panel with your eye easily, which was part of the goal.
I'm bothered by the cheese factor of putting tape on the otherwise elegant
panels. I don't consider this a final solution, but the good news is that I
can pull it off at any time. I have at least validated the concept of panel
separator graphics.
It would be simple to make up a jig that masks off the rest of the panel so
you could spray paint just the edges. This however would be permanent, and
would make the panels nonstandard with everyone else's (unless I could
convince all MOTM owners to adopt my solution).
So I'm still convinced that the coolest solution is metal edges that just
bolt over the top.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
