Milter-greylist
Index last updated: 2026-04-28 23:32 UTC
Re: reproducible crashing
2016-11-16 by manu@...
Marcus Schopen <lists@...> wrote:
> regarding to my todays post "weighting blacklists" I can reproducible
> crash milter-greylist with this configuration:
Could you please run milter-greylist in gdb and collect a backtrace?
Make sure you build with -g, then:
# gdb milter-greylist
(gdb) run [options] -D
Once crashed, issue the bt command in gdb.
Emmanuel Dreyfus
http://hcpnet.free.fr/pubz
manu@...
Re: [milter-greylist] Re: reproducible crashing
2016-11-16 by Marcus Schopen
Hi Emmanuel,
Thanks for your time.
> Once crashed, issue the bt command in gdb.d
I've attached the debug, mail.log, greylist.conf and the patches of the
debian package.
The only patch I provided is in the srs_filter file and it's about our
"block SRS senders" discussion (03 Sep 2016). All other patches came
with the official packages (version 4.3.9-1 maintained by Paul Martin),
which I used as template to build a new upstream release for 4.6.1. This
upstream package is installed on two of my live servers for about two
months and running stable. The milter crashes with this packages when
line "racl continue set $score=1" is part of config and the config is
changed while running.
System: Ubuntu 14.04 LTS
Kernel: Linux vorlage.testme.com 4.2.0-42-generic #49~14.04.1-Ubuntu SMP
Wed Jun 29 20:22:11 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Ciao
Marcus
"bt full" attached.
Ciao!
2016-11-17 by Marcus Schopen
I built a package without striping:
debian/rules:
override_dh_strip:
	dh_strip --exclude=milter-greylist
backtrace with symbol table infos attached.
Ciao
Marcus
2016-11-17 by manu@...
Marcus Schopen lists-yahoogroups@... [milter-greylist]
<milter-greylist@yahoogroups.com> wrote:
> #5  0x000000000041266c in ?? ()
> No symbol table info available.
> #6  0x000000000041469e in ?? ()
> #7  0x00000000004153a5 in ?? ()
> #8  0x00000000004105aa in ?? ()
Did you build with -g ?
Emmanuel Dreyfus
manu@...
As far as I know, that is not enough, you need -g in CFLAGS in order to
have gdb debug symbols.
Emmanuel Dreyfus
manu@...
Yes, I think so, I saw "-g -O2" while building. Did you see my traceback
from this afternoon?
Ciao
Marcus
2016-11-18 by manu@...
Sorry, I missed it. Here we get the offending free() call. I will
investigate from this later today:
*** Error in `/usr/sbin/milter-greylist': double free or corruption '
#4  _int_free (av=<optimized out>, p=<optimized out>, have_lock=0) at
malloc.c:3840
#5  0x000000000041266c in acl_free_prop_string (ad=0x685528) at
acl.c:1847
Emmanuel Dreyfus
manu@...
2016-11-19 by manu@...
Hello
Does this patch fixes it? If you can also test a rule with a regex
I am interested too, since the same bug was probably there too.
--- acl.c.orig  2016-11-19 05:58:14.000000000 +0100
+++ acl.c       2016-11-19 05:57:39.000000000 +0100
@@ -1880,9 +1880,9 @@
 void
 acl_free_prop_string(ad)
        acl_data_t *ad;
-       acl_free_string((void *)&ad->prop->upd_data);
+       acl_free_string((void *)ad->prop->upd_data);
        free(ad->prop->upd_data);
        free(ad->prop->upd_name);
        free(ad->prop);
@@ -1914,9 +1914,9 @@
 void
 acl_free_prop_regex(ad)
        acl_data_t *ad;
-       acl_free_regex((void *)&ad->prop->upd_data);
+       acl_free_regex((void *)ad->prop->upd_data);
        free(ad->prop);
Emmanuel Dreyfus
manu@...
2016-11-19 by Marcus Schopen
Hi Emmanuel,
> Hello
Thanks a lot for your time. I built a new package with your patch (btw:
the patched lines are at different line numbers in my acl.c).
The milter still crashes, not after the first change of greylist.conf,
but for some strange reasons after the third change.
Debug, greylist.conf and my patchfile attached.
Ciao
Marcus
Re: [milter-greylist] Re: reproducible crashing [3 Attachments]
Because you hit another different bug! That you for digging that out.
Proposedf fix:
https://ftp.espci.fr/shadow/manu/fstring.patch
Emmanuel Dreyfus
manu@...
2016-11-20 by Marcus Schopen
Hi Emmanuel,
> Proposedf fix:
No crashes any more, tested for about two hours. :) Will you release a
new version?
Is that rule set correct?
racl continue rset $bl_score=1
racl continue rset $bl_listname=" "
racl continue list "my_bl_1" set $bl_score+=3 set
$bl_listname="%P{bl_listname}my_bl_1 "
racl continue list "my_bl_2" set $bl_score+=5 set
$bl_listname="%P{bl_listname}my_bl_2 "
racl continue list "my_bl_3" set $bl_score+=3 set
$bl_listname="%P{bl_listname}my_bl_3 "
racl "BL_DNSBL" blacklist $bl_score >= 3 msg "Bad reputation - %d [%i]
listed on too many DNS blacklists:%P{bl_listname}(hit
%P{bl_score})" flushaddr
I need to use "rset" to reset the bl_score property variable for each
new email, right?
And how to I set an empty quoted string (see $bl_listname=" ")?
Ciao
Marcus
2016-11-20 by manu@...
> new version?
Sure.
Well, your usage is more advanced than mine :-)
rset $bl_listname="" does not work?
Emmanuel Dreyfus
manu@...
>> new version?
> Sure.
I saw some postfix configurations with weighting of black and whitelists
and was looking for a similar easy way to do that with milter-greylist
postscreen_dnsbl_sites =
    dnsbl.inps.de*4
    zen.spamhaus.org*3
    list.dnswl.org=127.0.0.1*-3
No, "unknown token """ line 156".
Ciao
Marcus
2016-11-21 by manu@...
That one could work - or to wreck many existing config.Tell me how it
behaves:
--- conf_lex.l.orig     2016-11-21 01:27:55.000000000 +0100
+++ conf_lex.l  2016-11-21 01:28:09.000000000 +0100
@@ -65,9 +65,9 @@
 command                [Cc][Oo][Mm][Aa][Nn][Dd]
 lazyaw         [Ll][Aa][Zz][Yy][Aa][Ww]
 all            [Aa][Ll][Ll]
 delay          -?[0-9]+[smhdw]?
-qstring                "\""([^"\n]|\\\")+"\""
+qstring                "\""([^"\n]|\\\")*"\""
 regex          "/"([^/\n]|\\"/")+"/"
 dumpfreq       [Dd][Uu][Mm][Pp][Ff][Rr][Ee][Qq]:?
 binddn         [Bb][Ii][Nn][Dd][Dd][Nn]
 bindpw         [Bb][Ii][Nn][Dd][Pp][Ww]
Emmanuel Dreyfus
manu@...
2016-11-21 by Marcus Schopen
Hi Emmanuel!
> behaves:
Thanks. In my case it's working with configurations of all my machines.
Ciao
Marcus
