Add 2 headers to message
2016-08-31 by Alvaro_Mar=c3=adn
Hi, I've some rules to greylist "bad" IPs, and one last rule to add a header with the IP and country code of senders: racl whitelist default addheader "X-Mail-Country: IP: %i | Country: %C" Runs fine, but now, I want to add the SPF test result, so I've compiled milter-greylist to support it and I've added these lines: racl continue spf pass addheader "X-Mail-AuthResults: %QS" racl continue spf fail addheader "X-Mail-AuthResults: %QS" racl continue spf softfail addheader "X-Mail-AuthResults: %QS" so the file looks like: ... racl greylist dnsrbl "RBL" delay 5m racl continue spf pass addheader "X-Mail-AuthResults: %QS" racl continue spf fail addheader "X-Mail-AuthResults: %QS" racl continue spf softfail addheader "X-Mail-AuthResults: %QS" racl whitelist default addheader "X-Mail-Country: IP: %i | Country: %C" The problem is that only the last header (X-Mail-Country) is added. Logs: milter-greylist: SPF return fail (test code 3, result 1) milter-greylist: SPF lookup performed in 0.002375s milter-greylist: Mail from=x@..., rcpt=x@..., addr=X.X.X.X is matched by entry racl 659 continue spf fail [addheader "X-Mail-AuthResults: %QS"] [maxpeek -1] milter-greylist: Mail from=x@..., rcpt=x@..., addr=X.X.X.X is matched by entry racl 661 whitelist [addheader "X-Mail-Country: IP: %i | Country: %C"] [maxpeek -1] default How can I do it? If I use whitelist instead of continue for the SPF rule, the other one isn't added. Of course, I can use only one header to mix all the data, but I prefer separated headers, if it's possible... Thank you! Regards, -- Alvaro Mar\ufffdn Illera Hostalia Internet www.hostalia.com
